What do you think I will run?
Ok I am about to have the car finally done after being down for about 3 months. Am going to have Kooks 1 7/8 headers with speed inc true duals, Lid, K&N filter, Smooth boot, P&P throttle body with the coolant bypass, ported MAF, LS6 ported stage 3 heads, 24X/25X cam, SLP U/D pulley, 150 shot direct port N2O with a FJO contoller, Full fuel system, Full suspension like, LCA's, Torque arm, Drag bar, QA1 front and rear adjustable shocks w/ springs, SFC's, and Bogart's w/ Hoosier DR's. This will run though a fully built TH350 with a Man. valve body and a 3400 stall, with a 12 bolt full spool rear with 3.89 gears. Full race weight is 3600. The car ran at it's best a 12.12 with only the bolt ons and a 6 speed. What do you think I will be able to get with this setup?
The person at the shop helping put everything together seems to think I should run high 10's to low 11's on the motor and high 9's to low 10's on the nitrous. I am hoping to get a good 60' like, 1.50's to 1.40's, But that just may be wishful thinking.
