Possible Nitrous Leak?
Old Nov 20, 2007 | 09:36 PM
ViperJ's Avatar
Default Possible Nitrous Leak?
So i just bought my Vette last Thursday and it came with a nitrous kit on it. I filled the bottle and *though I programmed the window switch right. Anyway I left it last night with pressure still in the nitrous line to the motor (so the gauge was at 750psi) and this morning it was at 0? I know the bottle was closed but does that mean I have leak?
Old Nov 20, 2007 | 09:48 PM
~RedLineLs1~'s Avatar
Does the kit have a blowdown tube? Although 750psi wouldnt be enough to pop a disc make sure the burst disc didn't rupture.
It's possible you have a leak around the bottle valve. Fill it up and open the bottle and listen around. If it's leaking that much it's usually pretty easy to hear.
Old Nov 20, 2007 | 09:51 PM
Mike@HSW's Avatar
if you can, just get it filled up with compressed air, no sense in wasting nitrous if you have a leak. drop it in a bicket of water and look for bubbles.
Old Nov 20, 2007 | 10:03 PM
daniel6718's Avatar
mine does the same thing...after you close the bottle it will have pressure for 4-5 hours...the line itsnt completely leak proof...and all the fittings....as long as when you close the bottle it doesnt shoot to zero quickly your fine
Old Nov 20, 2007 | 10:21 PM
ViperJ's Avatar
Sorry, I am really new where would the blowdown tube be?
Old Nov 20, 2007 | 10:34 PM
Bullitt4110's Avatar
On the bottle, it would be a tube coming off the bottle and exiting outside of the car.
Old Nov 21, 2007 | 10:32 AM
BT03mach-1's Avatar
mine does the same thing so i took soap and water and checked all the fittings and found no leaks. I asked on another board and they said it just does it and no one knew y. I think it comes out the purge alittle but i don't know. mine takes about 6 t0 8 hours before the line is empty.
Old Nov 21, 2007 | 12:43 PM
Zero4488's Avatar
Restricted User
Well I remember that so I don't come one here complaining about leaks in the future....
