HSW kit questions
Old Nov 22, 2007 | 11:42 PM
AR15 guy's Avatar
Default HSW kit questions
I have a HSW sudden impact wet kit for my lt1. I was wondering what you guys use to drill the huge hole for the nozzle. It has a 2 piece nut that is pretty damn big. Not quiet what I expected. I'd say its on the 5/8'' or larger size.
I just about have everything I need to get this system up and running for spring. I just ordered a blow down tube, HSW purge kit, HSW bottle heater, nitrous outlet switch panel (for bling factor) and a nitrous outlet tranny tunnel mount. Should be fun.
With all that my msd window switch, wot switch, fpss switch, and a 255 lph pump I think I am good to go. I told myself I wouldn't half *** this and I don't think I have lol.
Old Nov 23, 2007 | 06:18 AM
DopeFedZ's Avatar
A drill.
Old Nov 23, 2007 | 10:10 AM
Rick@HSW's Avatar
If going into plastic we use a 9/16" drill bit...should be what you need. If going into a rubber bellow use a 1/2" bit and trim to fit for a tight seal.
let us know if ya have anymore questions or you can contact support direct:
http://www.harrisspeedworks.com/support/
Old Nov 23, 2007 | 12:25 PM
TARZAN's Avatar
If going into metal (such as your TFS elbow) you could simply drill and tap the elbow to accept the threads of the nozzle itself (and set the nut aside for a later use or a paper weight) .
-Will
Old Nov 23, 2007 | 02:01 PM
AR15 guy's Avatar
That is a good idea. I think I will just do that. Would be a much smaller hole and no need to worry about the nut falling into the throttle body.
Old Nov 23, 2007 | 02:18 PM
Matt@HSW's Avatar
Yes, you would just use a 1/8" NPT tap:
http://www.harrisspeedworks.com/shop/home.php?cat=325
If you do use the nozzle holder the nut is installed on the outside of the air intake, so there is no way for it come undone.
Old Nov 23, 2007 | 08:46 PM
AR15 guy's Avatar
I just looked at it and your right. If it wasn't so large I would use it but I think I will just drill and tap the elbow since it will leave a smaller hole. Thanks for the help.
Old Nov 24, 2007 | 12:20 AM
TARZAN's Avatar
Glad I could help
-Will
