Solid Roller with Nitrous?
Old Nov 29, 2007 | 09:45 AM
  #41
508Stroker's Avatar
Originally Posted by Slicknic
These are interesting conversations, I'm running stock oil pump, stock lifters and stock rockers. Hyd cam 246/249 632/628 and shift at about 7000-7200 on the spray.
Given, I'm not running 8's like some of you guys but I plan on it next year.
I'll probably make the switch to a solid roller set up this winter.
Are the stock rockers good with a solid roller? They sure work great with my current setup.
Noyzee said he uses stock rockers with his solid roller so I would take that as a yes.
I guess you are curious about what you need to go solid roller also. Do you need a solid roller cam or can you just slap solid roller lifters on a hydraulic roller cam, with correct length pushrods and go for it?
Old Nov 29, 2007 | 09:48 AM
  #42
Noyzee's Avatar
8 second mod
no, i use adj rockers for solid roller, stock rockers where on my 402 hyd motor
Old Nov 29, 2007 | 10:01 AM
  #43
508Stroker's Avatar
Doh! Way to read way too much info then say some **** from my memory haha.
