Solid Roller with Nitrous?
Old Nov 23, 2007 | 05:08 PM
Cliff's Avatar
Default Solid Roller with Nitrous?
How many of you guys have a solid roller motor with nitrous? What, if any benefit do you find running solid roller over hydraulic? Solid rollers should make more power and be more consistent at higher rpms. I just talked to someone who spins there hydraulic motor to 7500 to 8400 rpm's without any problems. This is an NA motor, so it does not see nitrous. He did say his motors are balanced and machined extremely well which is a must.
Old Nov 23, 2007 | 05:13 PM
sr71bbjr's Avatar
8400 rpms on a hyd. lsx motor??Sound like you talked to someone that didn't know there *** from there face.
Old Nov 23, 2007 | 06:46 PM
ATVracr's Avatar
Mine has been to 8,000 and we have a few guys and girls around here that have taken them past 8400.
Your *** --->
Your face --->
Old Nov 23, 2007 | 07:01 PM
GueSS Who's Avatar
Solid roller here....It is about your complete setup.....Solid roller needs a really good intake to be able to run at the higher RPMs effeciently. The more motor hp you make the less nitrous you have to spray to get to your goal. My solid roller 410 makes 602rwhp/720through a TH400 and 9in. I spray alot of dry nitrous.
Old Nov 23, 2007 | 07:43 PM
ShiznityZ28's Avatar
SOunds like you dont know your *** from your face.
Mine has been to 8400 plenty of times but the most recent cam liked to be shifted at 7800 or so with the light set it 7600
As for the original post. just having the exhaust valve be able to open under all that pressure is worth HP. and having more area under the curve on the given duration is PIMP!
Mine is hydrolic but i sold that its be solid next year
Old Nov 23, 2007 | 08:50 PM
Cliff's Avatar
Not to make fun of you, but this car is here on LS1tech and it runs 9.6 on motor, true street car and the driver is a women. Doesn't that beat all. A women showing men how to race.................I love it!!!!!!!!!!!!!!!!!!!
Old Nov 23, 2007 | 09:09 PM
Noyzee's Avatar
8 second mod
I run a solid roller, i run it up around 8,000 do to the heads, my car seemeded to like 8,000 over that the heads didnt want anymore.
i know a ple of guys spinning to 8400-9,000 with solid roller with spray.
i realy like my solid roller it seems to keep everything smoother imo, hydrolic works, but solid to me is a little more forgiving with lifters ect.
Old Nov 23, 2007 | 09:46 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Right now I'm hindered by budget, but I'd love to run a solid setup.
Originally Posted by GueSS Who
I spray a lot of dry nitrous.
Slight understatement
Old Nov 23, 2007 | 11:06 PM
GrannySShifting's Avatar
[QUOTE=sr71bbjr]We from texas!
[QUOTE]
We not!
Old Nov 23, 2007 | 11:46 PM
sr71bbjr's Avatar
Ambers car??you think here valve train is just a regular hydrolic roller ??LOL.Anyone who spins a hyd. car to 8400rpms is asking for problems.I've spun my street cars to 7400ish without issue aswell.I wouldn't grind a cam for a hyd. car that would need to be spun that high to make power though.why not put a lifter in and be dun.
Old Nov 23, 2007 | 11:55 PM
sr71bbjr's Avatar
Your *** --->
Your face --->
So you think because your car has been to 8k that it's safe??I understand with ti. valves and other supporting valve train it can be dun(ambers car),but why in the hell would you want to?Anyone that would recomend spinning a hyd nitrous car that high is a ******* idiot.Peroid!
Old Nov 24, 2007 | 12:05 AM
Yup pal, were all idiots. No titanium valves here, just single springs and stock diam duals. This stuff won the pump gas drag this year, another most legit 9 second street car at the PGD, last year ATV did, finished 3rd in the LSx NA class because we stayed together making passes (not because the chits fast ) and one is currently the fast hyd NA car.
How many times have you been 8.9s or 9.0s and driven your nitrous car home? We can so we choose to build em. Nitrous and rpm get along quite well, and were lazy so we made it happen.
Old Nov 24, 2007 | 12:16 AM
ambers and joes car might only see8400 AFTER the shift, its a good ways above thats slightly prior
Old Nov 24, 2007 | 12:46 AM
LSXS10's Avatar
What lifters are you guys runnin??? Mine are stock 2003 6.0 lifters and they pump up or lose prime when i hold it past 6500 out the back door they sound like hell till i get back to the pits and the rattle goes away.....
Old Nov 24, 2007 | 01:00 AM
my 45k stockers are clean thru 7400, you losing oil presure or foaming the oil? cam lobes and springs have the most say so
7500 rpm comp 850-16s have nevergivin us 1 prob
Old Nov 24, 2007 | 01:31 AM
sr71bbjr's Avatar
How?? Please inlighten me...I've been around a long time and never have heard of someone spining a hyd. roller to 8400rpm's on nitrous .Teach this old dog a new trick.I'm all ears.
Old Nov 24, 2007 | 09:00 AM
No. Didnt figure this stuff out to listen to you spout off w/o looking both ways before you crossed the street and then turn around and tell you how to do it. If it cant be done though for $500 Ill let you adjust the rockers on a couple cyl so you can see its hyd or look at the stock rocker arms on Shiz car... if it aint Ill give you $500
I can understand having that attitude if YOUVE never done it, but when a few guys tell you they do it all day, then the old dog should realize maybe so... 23 I guess is new dog timeframe? lol
You dont haveta, but I like rpm with lots o cyl pressure around, so we turn rpm
Old Nov 24, 2007 | 10:23 AM
Robert56's Avatar
Grannyshifting, do see a benefit from a more aggressive cam profile running solid lifters compared to hydraulic? Seems, once you get to a certain rpm the dynamics of how the hydraulic lifters work, would place the solids at the forefront of efficiency. Insight?
Robert
Old Nov 24, 2007 | 10:42 AM
solid is without a doubt moreprecise control...how much more precise is the question, is it necessary for what you want to do. Shiz car went 157 at 3300 lbs with an iron block and simple afr 225s that was enough
Definitely SOMETHINGtogain by having a solid lifteropeningup against the gas load of a nitrous engine, but can be done well enough to go fast
ashleys car has been 9.6 so far, that was enough
Old Nov 24, 2007 | 10:44 AM
LSXS10's Avatar
Hummm ... all of mine has less than 5,000 miles 600 lift springs and 560 lift cam , it may be an oiling prob but it has an slp ported oil pump.. any suggestions????
