Nitrous Safety from Dynotune at $99!!!!!! IN STOCK!!!!!
#65
LS1TECH Sponsor
Thanks for the interest guys!
They are $119 - is your motor worth that?
Check out the features!
--Microprocessor contolled
--Built in Air/ fuel ratio display(narrow and wideband)
--Built in TPS (WOT) Switch
--Peak and Min A/F memory during the run
--Multiple outputs 12V and Ground
--Multiple Trigger inputs 12V and ground
--Programable trip points
--Adjustable delay to let lean spikes settle
--6 Foot wire harness Light Weight
--12 Volt Operation
--Fast response
--Super Low Current
--Draw Micro Package Mounts Anywhere 1.8" Wide x 2.4" Tall x .9" Deep
Dean
--12 Volt Operation
--Fast response
--Super Low Current
Dean
#66
could this work for a 2 stage setup?
-1 msd pilled window swicth that provides a ground for the a/f safety.
-1 a/f safety provides 2 separate grounds to 2 separate relays(when the tps is 100%).
-2 separate activation switches provide power to each of the relay to give power to the separate solenoids.
and will the a/f safty stay on showing the a/f even though the window switch does not give it ground while cruising?
#67
LS1TECH Sponsor
You could use switches and swap in/out stages...It will not care about that, it will think your lifing on/off the gas etc....
Dean
