The New HSW Interface Air to Fuel & Timing Controller
Robert
Matt
But Again If Your Iat Is Heatsoaked Even If You Tell It To Only Pull timing At A Certain Airmass Or Rpm You Still Are Stuck With A Heat Soaked Iat............ Accordingly Your Still Commanding For The Unit To Pull Timing (even If Its Only At Higher Airmasses Or Rpms)
The Problem Again Guys Is Lets Say Im Sitting At A Long Light (or Stageing Lane) And The Iat Becomes Heatsoaked (which Dosent Take Long) When I Go To Leave The Light It Will Take Over 1 Min To Cool Back Down......... Therefore If I Go To Leave A Light At Wot (off The Bottle) Im Still Gonna Hit The Higher Airmass\rpm Cells And Accordingly I Will Be Only Running N20 Timeing.. Although This Is Not A Huge Deal It Kinda Defeats The Purpose Of Using The Interface (over Just Running A N20 Tune)
also if your gonna go as far as to build a airmass based tune you really dont have a use for the interface anymore.. as i could just go into the main spark table and pull timeing by airmass
if the interface could command a higher iat or even a iat of -40 it would be far less likely that it would be hit unless the unit was activated
i personally chose to just use that iat vs rpm modifer to controll the interface but both of these are just band-aides that still bring you the the eventual conclusion that
for the interface to work properly on f-cars you need to resolve the heat soak issue and use custom tuneing
common now i know you know better than that ...the iat gets heatsoaked from the underhood radiating heat and your iat reads 158 even with out a interface..
the only reason this is not so noticeable normally is that
1: the iat can only pull a max of 3 deg
2: the iat vs rpm modifer is set to fade this out as you increase rpms
when you go to modify your iat table to pull timeing for a decent sized shot these problems come to light....
the only reason this is related to the interface is that using a resistor mod you can command higher iat's that you dont hit while the interfaces inablity to command higher iats leaves it unable to be properly used in a f-car without suffering other complications
Matt
I can't think of a time when my IAT has come anywhere near 158°, maybe a true CAI that pulls ambient air, and there are some on the market for the F-body isn't there? there are numerous CAI that pull ambient for the Vettes. Anyway, some more good info that points out some of the fine tuning that can be done, and a good tuner would know this right off the bat, yes, I missed it, but am only a hobby tuner and still learning also, but feel that I do have a pretty good grasp on things. JP, wish you were close by, I would love to help get things sorted out, kind of a challenege as your IAT moving may be the answer as I know others have moved it for various reasons.
Robert
Robert
Im Telling Ya' The Air Lid Iat Sensor Just Cooks And It Only Takes A Couple Of Secconds.. Also Once Its Hot It Stays Hot For Like 2-3 Min Of Driving Its A Huge Difference From The 5 Wire Maf Setup
Obviously the bottom two plugs are to plug into the MAF and IAT...and I'm guessing the other one goes to the interface?
What do the old MAF and IAT plugs plug into?
Robert
