The New HSW Interface Air to Fuel & Timing Controller
Old Nov 28, 2007 | 05:06 PM
Matt@HSW's Avatar
Default The New HSW Interface Air to Fuel & Timing Controller
They are on pre-sale until they start shipping out next week.
Introducing the world's first Air to Fuel nitrous controller; The HSW Interface. With The Interface controller you can now easily fine tune your air to fuel mixture without the hassle of swapping fuel jets or worrying about the nozzle placement in relation to the MAF sensor on your dry nitrous system. In addition to full control of your A/F curve The Interface can also retard timing when your nitrous system is active, so you can now run full timing NA and make max horsepower & torque and then safely and easily pull timing when your nitrous system is activated. Unlike some other timing controllers The Interface will show the timing being pulled when using a scan tool, so no more worrying if the timing is actually being pulled. The Interface can be easily installed into a pre-existing nitrous system and includes a pre-made wire harness for a simplified installation
Examples of Using The Interface:
Running a Dry Direct Port
Running a Dry Nozzle after the MAF Sensor (or before the MAF Sensor in a poor location)
Running a Dry Plate Kit
Adding fuel to a Wet Direct Port Kit (instead of wasting time changing fuel jets around)
Adding a little extra fuel to a Wet Kit to cure any "Lean Spikes" upon kit activation
How Does The Interface Work?
The Interface makes Air to Fuel adjustments using your Mass Air Flow (MAF) Sensor. Simply program The Interface as to what size shot you are running (adjustable from 5 HP to 315 HP in 5 HP increments). Full control over the A/F curve is now possible, allowing fuel to be added or subtracted. Timing control is done with the vehicles IAT Sensor. The Interface has a built in Diagnostics Mode & Safety Features. If the Interface detects anything wrong with the MAF Sensor it will not allow the nitrous system to become operational and trigger a Service Engine Soon (SES) light until the issue is resolved.
Feature Set of The Interface:
Air to Fuel Control
Timing Retard
Top End Engine RPM A/F Correction (Addition & Subtraction)
12 Volt or Ground Trigger (for easy integration into a pre-existing N2O system)
Adjustable Delay feature to prevent an initial "Overly Rich" condition (Rich Spike)
Built in Safety Features & Diagnostic Mode
More Info & Pricing: http://www.harrisspeedworks.com/shop...roductid=16953
Old Nov 28, 2007 | 05:20 PM
supersickss's Avatar
so do you need the interface controller also?
Old Nov 28, 2007 | 05:35 PM
Matt@HSW's Avatar
The Interface is the controller.
Matt
Old Nov 28, 2007 | 06:42 PM
Robert56's Avatar
That should really make all existing dry hits the bomb. I'll be looking to get one in the very near future. More and more, seeing no need to run wet hits, lol.
Robert
Old Nov 28, 2007 | 07:01 PM
gi8e7oi825's Avatar
So does this plug between the MAF sensor and the PCM?
Old Nov 28, 2007 | 07:17 PM
john563's Avatar
Does this have a window switch built in? Either way great product!!!
Old Nov 28, 2007 | 07:26 PM
Rick@HSW's Avatar
the harness that comes with the kit just plugs inline with the MAF sensor.
Old Nov 28, 2007 | 07:27 PM
Rick@HSW's Avatar
no it doesnt....and thank you.
Old Nov 28, 2007 | 07:37 PM
~RedLineLs1~'s Avatar
Thats awesome. Good price too! Pitty Christmas is taking my money. I look forward to adding another HSW product to my nitrous system in '08.
Old Nov 28, 2007 | 08:11 PM
Jpr5690's Avatar
What If You Are Using Cust. Maf Tables For A Uncalibrated Gm Truck Maf
Old Nov 28, 2007 | 08:35 PM
Blackbirdws6's Avatar
Sounds like a nice product and I like the plug-n-play portion with connectors. Price isn't bad either. If you remember the wet plate kit I have on my car, can I simply install this and program in the shot I'm running and it will take care of the rest? It will retard my timing for the shot and increase or decrease the amount of fuel? If you recall, I was running pig rich on my 100 shot (somewhere in the 10.1:1 area) so will this correct it a bit?
edit - just read the examples more closely, seems this may only help if my wet kit was running lean or have a lean spike which it doesn't. Am I correct?
-Brian
Old Nov 28, 2007 | 09:04 PM
Krazy98Z28's Avatar
This is used so you guys can run a N/A tune in the car and when you hit the nitrous it will automatically take out timing, so you don't have to keep switching tunes.
Old Nov 28, 2007 | 09:18 PM
slow89rs's Avatar
Sounds great but how do you program the unit? Does it hook up to my home computer or are there dip switches? Can I change the amount of timing that is being pulled for a given setting? Will the unit tell me the air/fuel ratio so I know to add fuel or remove fuel?
Old Nov 29, 2007 | 01:28 AM
TARZAN's Avatar
I'll probably be pestering you about these soon enough
-Will
Old Nov 29, 2007 | 10:02 AM
Matt@HSW's Avatar
No prob on the MAF table, the MAF will need to be a calabrated one for your application.
Matt
Old Nov 29, 2007 | 10:04 AM
Matt@HSW's Avatar
If you wanted to run your LT1 TNT kit as a dry one this controller would control the fueling, or if you wanted to pull timing when the nitrous activates and run full timing NA.
Matt
-Brian
Old Nov 29, 2007 | 10:06 AM
Matt@HSW's Avatar
Yes, that would be one use of the controller. You don't have to use the fueling portion if you don't want to, you could use it to strictly pull timing.
Matt
Old Nov 29, 2007 | 10:07 AM
Matt@HSW's Avatar
Switchs, no computer needed. All settings can be changed. To check A/F you would use a wideband O2.
Matt
Old Nov 29, 2007 | 10:10 AM
Matt@HSW's Avatar
Pester me lol, let me know if you have any questions with it. We're working on a customers sheet metal intake, it'll be a sick dry direct port. I'll try to get some picts when it's done.
Matt
-Will
Old Nov 29, 2007 | 01:21 PM
Mike@HSW's Avatar
ttt..
