The New HSW Interface Air to Fuel & Timing Controller
Old Nov 30, 2007 | 09:41 AM
  #41
STRIPSTAR's Avatar
Where on my manifold do you drill the nozzles for DP? aside from the obvious stuff we would need 8 nozzles, lines and 1 noid?
Old Nov 30, 2007 | 12:51 PM
  #42
RedBaron's Avatar
"Simply program The Interface as to what size shot you are running (adjustable from 5 HP to 315 HP in 5 HP increments)."
Why the 315 HP shot limit? Any way to increase this?
Old Nov 30, 2007 | 01:00 PM
  #43
TARZAN's Avatar
Make sure and send me some pics of that direct port ya'll are working on man, I need a new wallpaper on my laptop lol
Also, I'm gonna PM you, got some questions about the use of this, on shots of possibly 315+...
-Will
Old Nov 30, 2007 | 05:30 PM
  #44
Matt@HSW's Avatar
Sorry, you lost me, are you asking how the buttons are configured for the timing portion?
Thanks,
Matt
Originally Posted by PAGregSS
Ok, I'm really interested in this for just the timing retard portion. Matt, I'm currently using a Timing Tuner. Does your product adjust the amount of timing pulled constantly or do you set a specified value, like you do with the Timing Tuner? Or to word it another way, does it retard timing real-time and adjust accordingly?
Old Nov 30, 2007 | 05:32 PM
  #45
Matt@HSW's Avatar
Yes, we can go up in size, we would just configure the unit for your needs.
Thanks,
Matt
  #46
Matt@HSW's Avatar
PM back to you.
Matt
-Will
Old Dec 1, 2007 | 12:58 AM
  #47
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
On the dry DP could you just run one large solenoid and d. block into 8 nozzles? What style nozzles are you using too? I know there's quite a few; straight, fan, 70 degree, etc...
Old Dec 1, 2007 | 12:00 PM
  #48
Matt@HSW's Avatar
You could if you wanted to, all of the dry DP we have done used 2 along with our 70 degree nozzles. We should have some of our dry direct port kits on the website soon.
Matt
Old Dec 1, 2007 | 07:58 PM
  #49
HPT BANDIT's Avatar
On a dry shot before the MAF, will the maf still try to add fuel even with the interface activated or will it bypass what the MAF said and just ad the additional fuel for the HP shot you set the interface for?
Old Dec 1, 2007 | 11:11 PM
  #50
BLAKE 01 WS6's Avatar
matt p.m. sent
Old Dec 1, 2007 | 11:16 PM
  #51
also when is the sale over. i just need to make sure it will work for my car before i buy it. thanks
Old Dec 2, 2007 | 12:00 PM
  #52
FRUSTRATED T/A's Avatar
So how does it correct a/f ratio if im not using maf. i have hptuners, and hsw 125dry. sorry if its been asked a dozen times already, kinda need fine detail.
Old Dec 2, 2007 | 02:10 PM
  #53
Matt@HSW's Avatar
If the nozzle(s) is before the MAF and is positioned correctly (correct A/F) you won't use the Interface to add fuel, just use the timing portion. If the nozzle(s) are before the MAF with bad nozzle position (running lean) you should start at the correct jetting, so if you are running a 100 shot jet have the Interface set for a 100 shot, and then you can fine tune if need be.
Matt
Old Dec 2, 2007 | 02:11 PM
  #54
Matt@HSW's Avatar
This week.
Thanks,
Matt
Old Dec 2, 2007 | 02:12 PM
  #55
Matt@HSW's Avatar
If running in SD you can't use the fueling feature.
Matt
Old Dec 2, 2007 | 02:18 PM
  #56
brokenfly's Avatar
Matt
damnit... anything down the road???
Old Dec 3, 2007 | 05:05 AM
  #57
This week.
Thanks,
Matt
thanks i will order mine in a little while
Old Dec 3, 2007 | 07:38 AM
  #58
PAGregSS's Avatar
Sorry, Matt. I know I didn't explain myself very well. I may be thinking too far out there.
What I really wanted to know is that do you set the retard to say -4 degrees and it pulls that much timing all the time or does it actually vary the amount of timing pulled as necessary? I suspect that it doesn't as it'd need to interface with knock sensors and such to determine if more timing needed to be pulled.
Thanks,
Matt
Old Dec 3, 2007 | 02:30 PM
  #59
PowerShift408's Avatar
I'll definitely be picking one of these bad boys up, awesome product from HSW!
Old Dec 3, 2007 | 03:10 PM
  #60
OWN3D BY MY PROF!
Matt
What can we look forward to cost wise for a dry direct port setup?
