The New HSW Interface Air to Fuel & Timing Controller
Matt
Matt
This MAF sensor uses a unique connector. A new connector with wires is included for hard wiring the MAF sensor into your vehicle. If you don’t want to have to rewire the connector, plug-and-play adapter harnesses are available also from LPE for most applications.
I couldn't find any info on the Halltech's. I have this picture of the TSP one. It says it has a wiring adapter harness, but I'll let you tell me.
The wire harness in the pic is a 5 pin to 3 pin MAF, along with a 2 pin IAT. I assume you would be using the adapter harness? If you are you will want the LS1 version of The Interface, as it has a 3 pin MAF harness. If you are going to re-wire your vehicle for the 5 pin MAF you can use the LS6/LS2 version of The Interface.
Matt
What about the aftermarket 100mm mafs? I'm not sure of the wire setup on those. I checked lingenfelter's site and it said....
Matt
i want a 150 dry hit what would your ideal kit for me include? the plate? dual nozzles? of corse the interface, right?
http://www.harrisspeedworks.com/shop...cat=365&page=1
Great kit for the price.
