compression for nitrous
Old Dec 1, 2007 | 02:15 PM
DTRtransam02's Avatar
Default compression for nitrous
i would like to know the best compression ratio to go for a 408 would like to spay atleast a 200 tops 300
Old Dec 1, 2007 | 02:22 PM
TARZAN's Avatar
I'd say you need to decide if you want a car that performs best on motor, with a lil juice on that.....or a car that isn't the best on motor, but loves a healthy shot
-Will
Old Dec 1, 2007 | 02:38 PM
well i would like a lil of both still to run hard on motor but still take a 300shot and still be safe does nitrous like compression or does it need to be low
Old Dec 1, 2007 | 03:01 PM
JL ws-6's Avatar
Race your car!
Alot will depend on what you want to run for fuel n/a, if you're willing to run good fuel all the time then I'd go somewhere in the 13 to 1 to 14 to 1 range.
fwiw my 402 is 13.5 to 1 and @ 3500 lbs runs 10.5 on motor, 9.77 on a 100 shot, 9.61 on a 150 with a worse 60 foot time.
Motor was built for a 350 hit, which I'll never push it to.
Old Dec 1, 2007 | 03:09 PM
wow i was wanting more of a pump gas car something like 11.5.1 but had people telling that it was to much compression that you need to have low compression for nitrous
also had texas speed telling me that nitrous loves compression is that true
Old Dec 1, 2007 | 03:30 PM
TARZAN's Avatar
If you intend on staying 200 or less on the kit, you should be fine with the 11.5 comp. And still perform well on motor....
-Will
Old Dec 1, 2007 | 03:37 PM
so no more that 200 man that suxs i want atleast to have a 300 shot as an option
Old Dec 1, 2007 | 04:05 PM
stainless40cal's Avatar
11.5 with a standalone run pump gas all day and and just have the race gas come in when your using the nitrous perfect set up for some one who wants to run pump fuel pretty much all the time.....
Old Dec 1, 2007 | 04:07 PM
yeah thats what i was planning on doing but would want to be able to spray a 300 is that possible
Old Dec 1, 2007 | 05:08 PM
JL ws-6's Avatar
Race your car!
If you want to run nothing but pump gas, I would build a 10.5 to 1 motor and not even consider more then a 200 shot.
Race fuel, just makes things a TON easier, if you don't mind running a 118nos fuel in a standalone, I'd go 11.5 to 1 and keep it under 200 still, but I air on the side of caution.
There's people that have sprayed WAY more then that on more compression, but again I air on the side of caution.
I can tell you, my 13.5 to 1 went from 10.5 n/a to 9.77 and picked up a solid 10 mph on a 100 shot, and went 9.63@139 with a tenth slower 60 foot time (meaning I'm at the limit of my current suspension/tire setup) so the higher compression certainly liked the nitrous, that is for sure.
Alot of it depends on what your final goal is, if it's a 300 shot with pump gas, you're gonna be back to a 10 to 1 compression motor, so doing any serious n/a speeds @ the track are gonna get alot harder at that point.
Old Dec 1, 2007 | 05:28 PM
my plan was to run pump gas n/a then when it came time to spray i would bump it up to race gas on a stand alone fuel system at 11.5.1 compression
Old Dec 1, 2007 | 07:19 PM
leadfoot100's Avatar
I run 11.5:1 comp, 110 gas ON and OFF the bottle. it idles like **** with 93.... im guessing thats probably not a good thing then. eh, whatever, its a carbed 383 and tuned for 110 so i guess it would idle hard on pump
Old Dec 1, 2007 | 07:22 PM
and how much do u spray
Old Dec 1, 2007 | 07:24 PM
Ego Killer's Avatar
my 408 is about 12:1 and I was told it would handle 300 easy by TSP. but Im gonna start with 200 and work my way up
Old Dec 1, 2007 | 08:17 PM
JL ws-6's Avatar
Race your car!
200 is alot to start with, I'd put the timing and whatnot where you think you need it for the 200 you're planning on running, and jet for 100 and make a run... better safe then sorry. If all looks good, put it to 150, go again, all looks good then go to 200.
Just tossing 200 in there is asking to have a problem, unless you already have a baseline to go off of with the car that you know 100% to be good.
Old Dec 1, 2007 | 09:17 PM
275 total.
75 out of the trap and 150 after 1.6 seconds (just past 60 ft.
Old Dec 2, 2007 | 12:16 AM
TARZAN's Avatar
Not trying to be rude, but it really sounds like you need to decide what you want to do, THEN decide what to build.....
Originally Posted by leadfoot100
275 total.
150+75=225
-Will
Old Dec 2, 2007 | 05:02 AM
i already have a 408 with a texas giant cam and afr 225 heads 72cc with 11.5.1 compression with all forged internals for a three hundred shot all day every day but was worried bout the compression cause had other people tell me i had to much compression for nitrous so not to be rude bro i would rather ask ?s before i blow a 8 thousand dollar motor up
Old Dec 2, 2007 | 05:52 AM
508Stroker's Avatar
I know it's not an LS1, but it may help a little. We have a pat musi built 11:1 406 in our 3rd gen race car. We are finishing up a few last minute things, then when the season rolls around we are going to wack it with a 350 shot. Once the chassis is set up and all is fine we will use both stages giving us 500-550 shot. It's not the compression ratio, it is all about the fuel and tune. Do lots of plug chops and keep tuning.
Old Dec 2, 2007 | 08:57 AM
TARZAN's Avatar
If its built for a 300 shot, and you have it tuned for it (the tune being the key factor here), then you should be ok....
-Will
