how much timing
Old Dec 1, 2007 | 04:28 PM
XX11SECZXX's Avatar
Default how much timing
how much timing should i pull out for a 175 shot on my 383? im running it at between 38-40 degrees total. its 9.8:1 compression.
Old Dec 1, 2007 | 05:19 PM
Robert56's Avatar
Not to be a dick, but a couple posts down the same question, yours at 2:28 and that one at 12:05.
Robert
Old Dec 1, 2007 | 06:51 PM
thechef's Avatar
Moderator
2 degrees per 50hp
Old Dec 1, 2007 | 08:37 PM
Cam72aro's Avatar
I used to pull 8 on my 14:1 406 with a 250 fogger on it. I rac 36 on motor and pulled 8 through the msd on the gas. I would pull around 5-6 as a starting point. The 2-3 for 50hp is a start but does that mean on a 300 shot to pull 18? No. Read the plug and look at the ground straps for the timing line.
Old Dec 2, 2007 | 07:05 AM
XX11SECZXX's Avatar
ive got an msd 6 digital so i can pull out the timing when i hit the kit. i was planing on going around 6. thanx
Old Dec 2, 2007 | 11:58 PM
1badA3Z's Avatar
I have always heard 2 per 50 also,just to be safe!
