Biggest Shot Recomended On A Stock Bottom End With A Dedicated Fuel System
Restricted User
I'm ordering a Nitrous Outlests dual stage direct port kit, and I was wondering...what is the biggest shot I could run on a stock bottom end with a dedicated fuel system running 103? I curious, cause I'm planning on running 400rwhp on motor, and I'm trying to figure out where I'll be once I get my new direct port. Let me know what you all think is best for me, and will prove to be the most effective...
I know Gimp98TNT was running a 250 shot on his stock bottom with great results. Too bad the ground took out the motor before he could blow it up. This was on near 3 seasons of spraying the hell out of it!
If you're running a dedicated fuel system why not run race gas in it?
I ran a 1 gallon cell up front and separate fuel pump and used c16 in that tank with a separate fuel system on the motor.
If you're running a dual stage kit on a stock bottom end I would run the first stage at 100 and add an additional 75 or 100 on the second stage.
So I personally would run 175-200 tops.
if it is a dd, i wouldnt go any more than low 500's rwhp.
My car isnt a DD just a fun time toy I plan to add a stand alone fuel system and spray a 200 shot ontop of my current mods ~400whp. I may also swap on some Patriot heads and really see how long this poor LS1 shortblock is going to last.
