Is this part worth the money?
Old Jun 26, 2003 | 07:10 PM
SNAXS's Avatar
Default Is this part worth the money?
http://www.dynotune.org/store/Script...p?idproduct=37
Tell me what u think. Do you think its worth it? Basically, buy it, dont **** up your motor if u run lean/rich...
Old Jun 26, 2003 | 07:49 PM
CAT3's Avatar
Restricted User
Default Re: Is this part worth the money?
Depending on use conditions, if your go-lean enough to damage, I personally wouldnt be able to react in time (I dont sit and watch guages during a race). Nice safety device, but I wouldn't see the practicality of it. Just my .02
Old Jun 26, 2003 | 08:56 PM
slow's Avatar
i don't see the stock o2's being accurate enough to catch it.
After seeing my friends 18:1 dyno run on a ZEX kit, and his AF gauge still pegging RICH, i am not a fan of the stock o2 sensors.
Ryan.
Old Jun 26, 2003 | 09:10 PM
SNAXS's Avatar
Hmmm...I wonder if someone has already tried this unit??
BTW: CAT3 it says that the Nitrous actually shuts off on its own if u run to lean...So you dont have to do it yourself. Sounds like a good item Ill go ahead and buy it and tell u all how it works.
Old Jun 26, 2003 | 09:14 PM
CAT3's Avatar
Restricted User
That would be nice. I admit I didnt read the write-up this time, but seen one before and it relied on the factory O2's, and as "slow" mentioned had always kept shutting off, and stuff. But, every car is different. Post up the results please.
Thanks.
Old Jul 3, 2003 | 06:55 PM
SNAXS's Avatar
Thanks.
Yes Sir!
Old Jul 21, 2003 | 08:21 PM
2001CamaroGuy's Avatar
Ryan.
had the same kind of thing happen to me......
my stock O2s read 0.960 volts on AutoTap (so I kept pulling fuel out up to) yet when I got on the dyno with a wide band I almost hit 15:1 A/F
I also no longer trust stock O2s for WOT testing.....
Old Jul 22, 2003 | 03:25 AM
383LQ4SS's Avatar
One other thing I have seen is that running race gas will throw your 02 readings off tremendously. Getting 13.0 AF on my NA dyno runs was netting me about .795 on my scanmaster. On 93 octane i usually see .880-.899 for that range.
But...this thing could come in handy. Ya never know!
