PICS.. Harris speedworks dry kit/ Dynotunes new lean shut off switch
you can mount the billet bracket the same as you would with the standard bracket. I know some of our customers have mounted there and took a picture, ill try to find it and post it up
your set up is pretty decent. only thing i can see for a sleeker install is a different bracket to hold the bottle, and less n20 line between your noid and nozzle, if thats even possible.
Mike, that bracket is sweet looking. i have nitro daves on my hump right now, will that bracket work at that location with the angles and mounting?
they are designed with a little bit more "show" in mind. but they are also very functional as well. rather then undoing the bottle from the bracket you simply pull out the quick release pins and the whole bottle is out with a sweet carrying handle. makes filling trips much much easier. I think the standard bracket looks just fine with your setup.
