anyone running ngk tr-7's?
scr is 11.5:1 and dcr is 8.5:1. 150 wet shot. car sees some kr on the street but none on the dyno. just thinking about everything before i take it apart.
Robert
I am running a good bit more compression though at 13.5 to 1 static, and the dcr is way up there as well. Torco 116 n/a fuel, torco 118 Nos blend for nitrous.
Robert
Robert
I run the 118 fuel because it's just added safety and that's what my shop uses with all the nitrous cars, so they know the tuning with it/jetting when using it. My nitrous tuneup is still well on the safe side, but again, better safe then sorry. I pulled every plug after every run when I went to atco and sprayed it the first time and every single plug looked great porcelan had a nice tan color to it, ground strap had ust about zero heat to it, etc.etc. I probably could have used the #8 plugs and been fine, but I had to buy plugs anyway so I went a step colder for the first trip to be safe. Better to start safe then start off too hot and hurt something.
IMO a #6 plug is a good n/a plug for under 12 to 1 compression, over 12 to 1 I'd go #7 n/a, or any nitrous at all with under 12 I'd run a #7, over 13 to 1 I'd run a 7 or 8 n/a and an 8 or 9, or even a 10 with nitrous, dependign on what the compression/size of the shot is.
I have a new set of all pros that don't accept acorn style plugs. I don't have the engine together, but what plugs would work in these heads that are comparable to a TR6/7/8 etc?
stockish compression 100 shot #6, more then 100 #7. 12 to 1 compression and a 100 shot @7, more then a 100 shot #8, 13 to 1 compression #8 with a 100 shot, more then 100 shot #9, etc.etc. It's probably overkill safe, but again, for the 16 bucks or whatever a set of plugs cost, why not start cold, see what they look like and go from there?
