Who makes a good nitrous cam?
Old Jan 3, 2008 | 02:06 PM
b00sted's Avatar
Default Who makes a good nitrous cam?
I'm looking for something that will work well with a stock cube, stock headed LS1. Spraying 200-300.
Old Jan 3, 2008 | 03:49 PM
Chris@NitroDaves
Guest
Posts: n/a
Your best bet is to Contact some of the Shops on the Right ----->
All are good shops and will set you in the right direction in cam choices.
-Chris
Old Jan 3, 2008 | 04:03 PM
b00sted's Avatar
I can get any cam I want made up, I was just looking for a few suggestions from someone running a similar setup.
Old Jan 3, 2008 | 04:56 PM
Chris@NitroDaves
Guest
Posts: n/a
ahhhhhh ok i get ya now. Are your heads going to be stock unported or stock ported?
-Chris
Old Jan 3, 2008 | 05:59 PM
b00sted's Avatar
Stock unported...Maybe just cleaned up a little if anything. Just running those and going to a Trickflow or similar down the line.
Old Jan 3, 2008 | 06:13 PM
Gimp98TNT's Avatar
I had good luck with a old Futral grind, it was .225/.233 .595/.600 on a 114lsa and i think the icl was 111. I went 9.70's with a 225rwhp shot and ported 5.3's.
Old Jan 4, 2008 | 10:47 AM
Chris@NitroDaves
Guest
Posts: n/a
I have ported stock heads and have had good results wiht my cam 228/232 .588/.595 112lsa
Chris
Old Jan 4, 2008 | 11:16 AM
Alan@XHP's Avatar
Closed ex-Sponsor Account
Thumbs up
With a stock bottom end I would go with one of our custom grind nitrous cams 239/245 .589 .596 114 LSA This cam will clear stock pistons. Just give us a call if you have any questions. Alan
Old Jan 4, 2008 | 12:53 PM
chad rock's Avatar
ms3 on a 114 here with 225 2 stage works great
Old Jan 6, 2008 | 04:03 PM
Noyzee's Avatar
8 second mod
6 speed or auto?
people throwing specs around like mad. lol
if its an auto, id throw an advance in it to get her moving out
Old Jan 6, 2008 | 04:39 PM
b00sted's Avatar
th350, rod/piston ls1 w/ stock crank, some cleaned up 241's, vic jr. intake with a carb.
