Couple of wiring questions!
1. Switched 12v sources, locations? I have a few that I use regularly on these cars. But Im curious as to where everyone else sinks them.
What are yours?
2. 14g enough for 5 switches power? Same with ground?
3. And your mounting your WOT switches where?
4. Inline fuses? The heater is the only one that requires one. But im tepmted to run a couple more.
Thanks guys!
http://i149.photobucket.com/albums/s...c/DSCF0119.jpg
i got this from a nother guy but heres were im mounting mine.
Mainly that it might not give an acurate WOT reading becuase all pedals a bit differantly.
Each switch (except the Opener and Line Lock) controls a relay. No issues to date.
Switches are
Arm Dry, Arm Wet, Purge, Line Lock, Opener (Heater is on the Trick Performance V Series gauge)
