3-stage 300 shot and MS4
Old Jan 4, 2008 | 12:30 AM
99mongooSS's Avatar
Default 3-stage 300 shot and MS4
I want to run my MS4 in my new motor setup, but I am going to run a 3 stage 300 shot. Its going to start out with a 75 shot out of the hole(I launch at 4000), then a 100 shot along with the 75 shot in second gear. the 75 shot will engage at 3700 then the 100 shot will come on at 4300 then the 125 shot will come on at 4700. I then will run the powerband to 6600 and hit 3rd and repeat the process. I know 300 is a large amount but, I've seen it done with these cams. If its multi-staged, and in higher rpm band when its engaged...Then wouldn't I be able to use my Magic stick 4?
Old Jan 4, 2008 | 08:10 AM
LS1SpeedAddict's Avatar
I would get a professional spec you out a custom grind for something that extreme
Old Jan 4, 2008 | 11:44 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Sounds complicated and expensive....A single stage with an RPM based progressive would be much cheaper.
Both the FJO and the new NOS Launcher will support RPM ramping and will let you program a curve that can add the power where you want it.
Old Jan 4, 2008 | 02:02 PM
RAGENZ28's Avatar
I think it would be more expensive than worth wild on a car only spraying 300 hp.
I would go single stage progressive and since you're having your motor built I would have a cam specified to your exact application.
Get something with at least a 114 and up lobe and I would try to get something with at least 8 or more degrees of duration on the exhaust side.
Old Jan 4, 2008 | 02:11 PM
b00sted's Avatar
Progressive...ew.
Old Jan 4, 2008 | 02:49 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by b00sted
Progressive...ew.
they work fine for me...and alot of other people out there
Old Jan 4, 2008 | 03:37 PM
99mongooSS's Avatar
I dont want progressive. Plus with stages i can leave all but like one big one off. I dont plan to hit all 300 with out a tune ( two different tunes downloaded onto diablo programmer) and race gas in the tank.
Old Jan 4, 2008 | 03:38 PM
99mongooSS's Avatar
and its not that complicated. the 75 shot is dry, the two big shots are wet nozzles.
Old Jan 4, 2008 | 03:44 PM
99mongooSS's Avatar
I just love my MS4 on motor, and I had a 150 shot on it for about 2 months and spun a rod bearing. I was hoping I could get away with it but I guess not. I have found that the supercharger cams seem to be almost the same as dedicated nitrous cams. I was looking at the blower grinds at speed inc. http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
They seem to be right around the specs im looking for. What do y'all think?
Old Jan 4, 2008 | 06:45 PM
Flaco's Avatar
Just go with a direct port and be done
Old Jan 4, 2008 | 07:00 PM
smokeum99ta's Avatar
MS4 with 300 shot here. I use a fjo mini controller to bring it on smoother but either way its badass.
Old Jan 4, 2008 | 08:00 PM
Robert56's Avatar
Good for you. I understand exactly what/why your doing what your doing. The progressive camp will never get it. But likely they will get it when one of their noids fail, lol. Progressives have been out for many, many years, and there is a reason the vast majority of serious racers don't use them.
Some of these guys use the progressive for traction, and that's a whole different ball game compared to going big and spreading the load out, and the easy option to chose what stages to use. Hell, for traction problems a digi timer works as good and is much cheaper.
Robert
Old Jan 5, 2008 | 01:04 AM
99mongooSS's Avatar
Robert
exactly! Thats another reason i wanted it set up like this is so that I can catch all the traction in each gear before the big hits start engaging. I have spent alot of time figuring out how to do it right, and I think this is the most direct way of injecting 300 hp worth of spray without the damaging effects of controllers and other stuff. I am however going to use an msd window switch on this setup.
Old Jan 5, 2008 | 09:54 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Robert
the classes I run in only allow 1 stage....so that is one of the reasons I am running a progressive.
Old Jan 5, 2008 | 11:11 AM
Robert56's Avatar
In the other thread you stated you were running it for traction, but both are valid if ya like progressers.
Robert
Old Jan 5, 2008 | 12:32 PM
99mongooSS's Avatar
yeah to each their own. Im not gonna dis anyone's setup, I just know in my mind what I want to do as far as my setup i was just wandering if an ms4 will work with up 300hp worth of spray. I know a few people doing it and ive talked to a few guys doing it. As long as i hit it above 3500 then i should be fine.
Old Jan 5, 2008 | 12:52 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Robert
it is the same thing.
I am limited to a single stage, I want to run a 300 shot....I can't hit it all at one time so I use the progressive to maintain traction.
Old Jan 5, 2008 | 01:10 PM
Robert56's Avatar
Put some bigger slicks on, lol. I guess that's why they limit you to one stage, but still it seems you could run as big of hit with a progressive as you could with a multi stge, so why the limit? You can do the exact same thing with either, spreading the hit out, makes no sense really?
Robert
Old Jan 5, 2008 | 01:15 PM
RAGENZ28's Avatar
The ms4 will work with any nitrous setup, now will you gain as much on the nitrous as running a specifically ground nitrous cam.. NO.
Old Jan 5, 2008 | 01:20 PM
99mongooSS's Avatar
that being said. What would I really lose going with the MS4 over a dedicated nitrous cam?
