Spraying your '03 Cobra...Priceless!
Old Jul 1, 2003 | 03:34 PM
unit213's Avatar
Administrator
Default Spraying your '03 Cobra...Priceless!
http://www.svtperformance.com/forums...919#post488919
Can you guys help me out too? I have no idea how to set up the WOT or the FPSS switch.
Old Jul 1, 2003 | 04:07 PM
JimD's Avatar
Default Re: Spraying your '03 Cobra...Priceless!
1. Can I run a wet kit or does it have to be dry?
2. Does the nozzle go right before the TB?
3. How do I set up the WOT switch
1 Wet kit is safer
2 single nozzle is fitted as close to TB as possible
3 Rig the WOT switch [micro switch] so that it operates at full throttle you'll need to make up a bracket You could always fit a TPS unit does the same job electronically
Old Jul 1, 2003 | 10:24 PM
BIG PD's Avatar
how may i ask do you put a shot after the supercharger? that cracked me up. you could but it'd be direct port and very expensive i'm sure.
Old Jul 1, 2003 | 11:08 PM
DetroitZ's Avatar
when you get it setup, you gotta take me for a spin in that beast. i imagine i don't live that far from ya
Mike
Old Jul 2, 2003 | 01:32 AM
SScam68's Avatar
I think the dry shot is the better way to go before the supercharger.
Its a non-combustable mixter where as a wet shot would be.
Old Jul 2, 2003 | 05:24 AM
unit213's Avatar
Administrator
sscam68- i think you're right. i'll do some research and find out the how to plumb evertything.
detroitz- i'd be happy to take you for a spin,
Old Jul 4, 2003 | 09:06 AM
redsscamaroboy's Avatar
No tech support here. I just wanted to say good luck and let me know what the BEAST runs after all is said and done.
Dave
Old Jul 5, 2003 | 11:38 AM
unit213's Avatar
Administrator
It's going to be nasty Dave. Count on it!
Old Jul 5, 2003 | 12:12 PM
Malicious's Avatar
Definitely, friend of mine shoots a 60-75 shot into his 03 with a lightning pulley and full exhaust and tuning and made 580/622 on the dyno with a frozen intercooler. 11.00's thus far launching easy so he doesn't break half shafts
Old Jul 7, 2003 | 08:54 PM
Hey Dan, I finally figured out my nitrous problem. The 5177 dry kit solenoids only flow 175 at the motor. They can not flow enough to support 150 to the wheels.
That is why i run the same mph on 75 /100/150 shot. My noid for nitrous can not flow anymore than that. 1 board member gained 144 at the wheels with no jets in at all,only restriction was the noid itself.
I am getting a new noid then returning to the track. Good luck with your new toy,keep me posted.
Dave
Old Jul 7, 2003 | 09:22 PM
unit213's Avatar
Administrator
Dave- Check your pm's.
