turbo+nitrous?
Jim C.
Jim C.
Also, what is you current fuel system? I'd probably advise a wet kit, simply to keep the extra strain off your injectors (since the boost already calls for loads of fuel). A nice lil 50 shot, from a single nozzle, would probably net you 60-75 HP gains on the dyno, and as Dave already said, offer some nice cooling effects for those otherwise warm IAT's.
I have run a 50 shot on my GN for awhile now, with no problems, and the car LOVES it.
-Will
Spoolin, I'd get it tuned, with boost+juice on a stock motor, every lil bit counts
-Will
Jim C.
Jim C.
As soon as I get mine in the car and the 88-mm hooked up I will be using both N2O and alchy as I have done many times on my GN to be able to run stupid amounts of timing in comparison to straight race fuel and keep a nice clean burn in the cylinders. The key to that combo is in the ignition.
Jim C.
