how do i know if my nitrous system is working
Old Jan 14, 2008 | 10:29 PM
Z28Caves60's Avatar
Question how do i know if my nitrous system is working
I got my 5177 kit all hooked up with a MSD window switch, purge kit, and bottle heater. Now of course i tired it out but i really cant tell if its working or not. I got the 75 shot pills in the thing and i really cant tell a difference. Is there an easy way other then just spraying the car to see if the kit is engauging and turning off when its supposed to??? any ideas..thanks
Old Jan 14, 2008 | 11:05 PM
02SS:ZEUS's Avatar
I'm assuming you're running off a WOT switch. If that's the case, leave the juice off, floor it in like 3rd gear. Then turn the nitrous on while you have it floored. You should feel the 75 shot kick in. It won't feel like much though. You'll be bumpin' it up to 150 before long.
Old Jan 14, 2008 | 11:07 PM
GrahamHill's Avatar
Weigh the bottle.
Old Jan 14, 2008 | 11:10 PM
waterbug1999's Avatar
Or pay for an hour of dyno time...
You should be able to feel the 75 shot though. Or at least hear the motors RPM change.
Do you have it set at 1st gear lock out? (not familair with your W.S)
Old Jan 14, 2008 | 11:59 PM
Randy WS6's Avatar
What bottle pressure are you running ? 75 shot @ 1100psi should fill like passing gear kicking in on a automatic at least. When i first put mine on i have problem with the fuel pressure safety switch not letting it in gauge.
Old Jan 15, 2008 | 12:32 AM
jmill96Z's Avatar
If you can't feel it, it's not working. Even on a 75 shot it will be night and day. First, check all of your grounds. The next easiest thing would be to bypass the window switch. If it still doesn't work, jumper WOT, and next the FPSS. Just remember to only jumper one safety feature at a time to narrow down the culprit.
Old Jan 15, 2008 | 05:54 PM
onoiocoko's Avatar
since ur in indiana, is ur heater working? i sprayed mine in 30 degrees just to see if it was spraying from about 40 (no heater). it never hit hard but i could see the mph climbing alot faster. if u don't notice anything then its probably not the heater.
Old Jan 15, 2008 | 11:34 PM
Z28Caves60's Avatar
I got the kit working just a couple of switched wires...But holy ****, now i know why you guys are crazy about this nitrous stuff. Man i only had a 75 shot at 950 psi. and it was a blast. I guess my nitrous cherry has been offically popped...
Old Jan 15, 2008 | 11:46 PM
Sweet... Just be carefull and make sure your A/F is in the sweet spot.
Old Jan 16, 2008 | 03:48 PM
Todd157k's Avatar
oops. That's all it takes.. yep, 150 shot by the end of the week. Anyone placing bets???
Old Jan 16, 2008 | 05:59 PM
MetallicaMatt's Avatar
well today is wednesday.....yeah i give him to friday at the latest, if he hasn't done it already
Old Jan 16, 2008 | 06:32 PM
2002t/a06's Avatar
and the addiction begins
Old Jan 16, 2008 | 07:01 PM
onoiocoko's Avatar
this isnt worth starting a full thread, but u auto guys trust running 150 on ur auto's? how long have u ran the stock auto before it blows? or are u using a pill kit to cut it before the shifts?
Old Jan 16, 2008 | 09:52 PM
Todd157k's Avatar
Window Switch controls it so you don't spray through a shift.. although there are several that just shoot through the shifts. Trans life will be shortened.
Old Jan 16, 2008 | 09:55 PM
2002t/a06's Avatar
yup, i used to spray through through shifts. now after i put a converter in im pretty sure my trans is circling the drain.
Old Jan 17, 2008 | 11:27 AM
Qwiknotch's Avatar
It's more fun to use nitrous with a stick and use a button on the steering wheel instead of the wot switch.
That's some fun!!!!!
