View Poll Results: change gears or change tires.
stick w/ the 4.11's now and swap to a 28" tire on gas
26
74.29%
swap to the 3.73 gears and run a 26" tire on gas
8
22.86%
swap to the .389 gears....what tire? 27"?
0
0%
other options....please post.
1
2.86%
Voters: 35. You may not vote on this poll
spraying 4.11's....change tire or change gear?
Race your car!
yours is a full strip car right?
the 3.70's would benefit me on the highway and not to say im going to but a roll race here and there would help w/ the traction and nitrous...
damn man im not sure what I want to do...4.11's would benefit me on the motor far more than 3.70's would, and thats where I will be the most...so 4.11's? decisions decisions.
Chad
Chad
My car is a strip only car, way past being able to drive it around, and I wouldn't want to anymore anyway. That being said, if I was gonna keep it n/a, I was gonna go to 4.30's with a 28 inch tire, or 4.56 with a 29.5 tire.
on spray you may have to switch to a 28" anyways because of traction with that m6 . i voted 4:11 but a 3:89 with 28" tires should get you past the stripe on spray before you hit the limiter.
the list before spray.
15" drag wheels/slicks
Twin disk clutch (not sure who yet...looking at McLeod)
UMI tunnel mounted torque arm
UMI SFC's
42 lb'ers.
then after all that and see how low in the 11's I can get...then we'll add the giggle gas, either the new dry maf kit or the nitro daves wet plate...but thats a hard choice.
Chad
but I'm also looking HEAVILY at the new NX dry MAF kit w/ the adj. a/f it seems like one hell of a trick piece...we'll see. I need all the other stuff first.
Chad
That's what she said...
I can chime in a bit. I run MT 315/35/17's, which are almost 26" tall. I made a track run standing on the 6800rpm limiter for the last 200+ feet and it went 124.5mph in 4th gear with 4.11's. I'm about to be swapping over to 3.73's, as the 124.5 was on motor.
4.11's come in Moser 12-bolts too, even though they call them 4.10's. There's 37 teeth on the ring, 9 on the pinion. 37/9 = 4.1111111111111111111111111111.
28x10.5 ET Drag
4.10 gears
300 shot out of the hole.
1.40 60ft
this was my first time out on the new setup at the time, as you can see i needed to shift to 4th (1/8 mile)
http://www.youtube.com/watch?v=0724awWcAHw
4.10 gears
1.40 60ft
Running 4.10's in a S60 and will be spraying a 150 shot on either a 325/50R15 or a 325/45R17 tire. I don't really know what affect it had on the motor but it will be better on spray.
#35
I'm running 28" MT drag radials
Moser 411's
TNT 100 shot
Trapping 125mph at about 6300 rpms.
So there's plenty of room for more mph with my limiter set at 6700.
Moser 411's
TNT 100 shot
