nitro daves
Thank you for the complement.
I appreciate you being so patient with us on the 85mm plate. It took the machine shop for ever to get those in the line up. It was sent off for polishing today to make up for you having to wait so long. I wish every customer was as understanding as you. This took us way to long...
I promise when you get your kit it will be all worth while. Getting on here and seeing that everything we are doing to try to make up for all the hassle you went through is still bringing a smile to you face brings a smile to my face.
Im sorry you are givin a hard time for showing alittle appreciation for us trying to make good on added fustration.
THANK YOU!!!!!
Dave
THANK YOU!!!!!
Dave
THANK YOU!!!!!
Dave
THANK YOU!!!!!
Dave
Thanks again for everything Nitro Daves
Looking forward to getting it and getting it put on
Currently the only things we have on back order are 90mm dual stage plates, 85mm plates, and dual stage windowswitches.
Dual stage windowswitches are on there way to us.
85mm plates are off to be annodized and they are machining dual stage 90mm plates now..
Everything else is instock.
Thank you for your support as well. You will love our dual stage plates....
Dave
Dave
thanks again for everything dave. i wish every company had the same quality of customer service. i just got my typhoon intake manifold ported and polished and port matched to the heads so between that and throwing on the 85mm plate i should be running some good times. im hoping to go low 11's and trap somewhere around 123-124 on drag radials.
From: The dirty taint of the country. ...Los Angeles
To Dave:
I was actually talking to Rob from Strictly and since I'm gonna be sqeezing, I told him that I was doing a lil research and then he just said that you knew each other and to order from you. So,.. you might be get'n a call from me in the upcoming weeks before LA Invasion.
