New NX dry maf results
Old Feb 18, 2008 | 03:58 PM
  #41
m6z's Avatar
m6z
is this available for purchase yet?
Old Feb 18, 2008 | 05:43 PM
  #42
383LQ4SS's Avatar
I sent an email to NX. Awaiting thier response. Send emails to NX or call and tell them to get moving!
Actually I know they are working on it...I just am not privy to the details.
Old Feb 18, 2008 | 05:48 PM
  #43
my01ws6's Avatar
Im going to call them tomorrow to find out when its gonna be for sale. IM FIRST IN LINE HAHAH!!!
Old Feb 18, 2008 | 11:13 PM
  #44
realmendrivev8s's Avatar
Kit sounds nice, think ill pick it up this summer and eventually add a NANO setup to it.
Old Feb 19, 2008 | 10:21 AM
  #45
dlove's Avatar
when doing a dual stage with this setup and adding a wet stage. Would you want the first stage to be the dry or the wet?
Old Feb 19, 2008 | 10:38 AM
  #46
383LQ4SS's Avatar
I have done a few dual stage wet/dry setups.
I always use the dry stage first..for several reasons.
1) a backfire is most likley to happen at low rpm with a wet kit....so hit the dry first when at the lower rpm or out of the hole. The wet kicks in when there is plenty of airflow...so less worry of backfires.
2) if you are going to use the dry nitrous retard method to pull timing (which I do) then the first stage must be dry so that timing can be pulled at all times when spraying. If you did wet first you would get no timing retard on the wet kit out of the hole which is the most important time.
3) if you are pulling the nitrous from both kits off one bottle you really need to tune the wet kit when BOTH the dry and wet are spraying...espcially if you are using a -4 line. But even a -6 line makes a difference. If you spray wet first and have jets for 11.5 AF ratio and have it tuned to that 11.5.....once you hit the dry the wet kit will then go rich because you have just slightly diminished nitrous flow to the wet kit by sharing the nitrous flow with the dry.
So I alway tune the wet kit ONLY when the dry is spraying for correct AF ratio and then I ONLY spray the wet in conjunction with the dry. Now that was with a typical dry kit in the past. With this new kit you could run the wet first and get the AF ratio at 11.5..and then dial in the dry just as easy....even if the nitrous is shared at that point. You couldnt do that in the past because there was no easy way to adjust for the dry.
Old Feb 20, 2008 | 08:13 PM
  #47
gator's 99TA's Avatar
damn how did i miss this post? awesome write up! i bet you like that ole beater camaro
i almost bought it myself!
i need this on my new motor al!
Old Mar 8, 2008 | 01:40 PM
  #48
JS's Avatar
JS
Please get The 90 Maf Done Asap
Old Aug 9, 2008 | 10:46 AM
  #49
red fury's Avatar
Has NX started shipping this system yet??? If they have not, they really dropped the ball.
Old Aug 9, 2008 | 11:12 AM
  #50
ShiznityZ28's Avatar
Originally Posted by 383LQ4SS
Me too. MY first dry kit was a solid 12.5 to 1 AF ratio all day long
I should have the final price soon. But my guess is between $749-$799
Keep in mind it comes with the autolearn TPS (instead of a WOT switch) and a mac daddy NX bottle with thier new valve that has two extra ports for accesories such as NANO or other gauges/sensors, and of course the MAF head unit itself.
I would have kept that one 12.5 is way closer than 11.5
Old Sep 8, 2008 | 07:06 AM
  #51
gi8e7oi825's Avatar
Any word on the release???
Old Sep 8, 2008 | 04:14 PM
  #52
caliswangin916's Avatar
it's probably dead. was told 3-4 weeks earlier this week. which means nothing.
and i was also steered towards a wet kit.
Old Sep 8, 2008 | 09:23 PM
  #53
Robert56's Avatar
Al is also MIA?
Robert
