Problems problems problems
Old Feb 3, 2008 | 07:23 PM
scottHMT's Avatar
Default Problems problems problems
I just put a ls6 manifold on my car, along with 28lb injectors, and i hit the nitrous and the car barely hits, then the exhaust starts popping and i throw it in neutral and it shuts off, i throw it back into gear and it turns on again and runs like ***, then after a few minutes of trying to limp it back home it starts running good, so i go make a few more NA pulls and its running fine with all the power it should have. I cant figure out why its running like this
and for some background info i have a HSW plate with a NOS kit, i havent used the nitrous in a good month or two, and bottle pressure was a bit low (700psi)
what im thinking is that the extra feul from the 28lb injectors vs the 26lb injectors are making it run a bit rich, but could it really make it run that much more rich? with the 26lb'ers i was at a solid 11.6 11.7 a/f ratio across the board. ARGH this thing is giving me a headache, im about to ditch the nitrous system and just throw a cam in this thing. Can anyone lend some info?
Old Feb 3, 2008 | 07:29 PM
scottHMT's Avatar
update, im a dumbass and had the feul and nitrous jets switched, running a 31 nitrous and 52 feul. No wonder it bogged out that hard.
Old Feb 3, 2008 | 07:34 PM
n2ocamaro's Avatar
That bottle pressure is pretty low. Need a little more info though. What is the set-up for the nitrous system? What size shot? Do you have a fuel pressure safety switch? Did you program for the larger injectors?
Old Feb 3, 2008 | 07:35 PM
n2ocamaro's Avatar
I guess I posted the same time as you. Yeah, that will certainly do it
Old Feb 3, 2008 | 08:02 PM
scottHMT's Avatar
I'm only running 100 shot, do you think I'll be good with the slightly bigger injectors?
Old Feb 3, 2008 | 08:12 PM
n2ocamaro's Avatar
Is it a wet or dry kit?
Old Feb 3, 2008 | 08:54 PM
Mike@HSW's Avatar
Your injectors will be fine. Wet systems do not rely on injectors to add the additional fuel.
Old Feb 4, 2008 | 09:37 AM
BQTransAm's Avatar
700psi is not going to hit hard at all.
Get it to 1000-1050 and hit it.
It will be a night and day difference.
Old Feb 4, 2008 | 09:39 AM
636SpecMan's Avatar
it happens. lol. i did that in my sentra and was dumbfounded when i realized my mistake.
Old Feb 4, 2008 | 12:49 PM
scottHMT's Avatar
Oh no doubt, the bottle is just low and it takes nearly a half hour to warm up to even 900psi, i need to get it refilled soon. But as for the hit, it dyno'd 436hp and 460tq on 100shot with just boltons with a HSW plate on 900ish psi. Im hoping with the ls6 manifold i'll be making about 450 on the 100shot.
Old Feb 4, 2008 | 01:07 PM
1320 killer's Avatar
sound like your running rich. try lowering the fuel jetting in your plate.
Old Feb 4, 2008 | 02:50 PM
scottHMT's Avatar
with the 26lb injectors I was at a steady 11.6 11.7 a/f ratio across the board, with the extra 2lb with of fuel from the 28lb injectors even matter? I guess I'll throw it on the dyno and see what she makes.
Old Feb 4, 2008 | 04:33 PM
Beer99C5's Avatar
Did you change your tune to reflect the change from 26 to 28's on the injectors?
Old Feb 4, 2008 | 05:06 PM
smokeum99ta's Avatar
Are you sure that there is nitrous in the bottle?????? You might want to get it filled up then try and spray it with 1000-1050 psi in the bottle and let us know what happens. If it takes a 1/2 hour to warm up theres probably not enough nitrous in the bottle.
Old Feb 4, 2008 | 10:23 PM
scottHMT's Avatar
tune? what tune? I know i need one badly. When i get the money I'll get it done, but its like 600 bux
Old Feb 4, 2008 | 10:29 PM
jmill96Z's Avatar
You need to tune for the new injectors. Just my .02
Old Feb 4, 2008 | 10:50 PM
U LUZ's Avatar
ther is quite a difference between 28 lb and 26 lb injectors..you need a tune..or put the 26 lb injectors in and spray the **** out of it at about 1000psi and it will be a world of difference.
Old Feb 4, 2008 | 10:57 PM
BayAreaSS's Avatar
I would put the 26lb'ers back in until you can get a tune.
Old Feb 5, 2008 | 12:29 AM
scottHMT's Avatar
Lol geez, you tune ****'s. Haha jk, im saving up for a tune, the car rarely gets driven anyway, and i hit the nitrous at the most once a month, but a tune is definately the next mod, that and a feul pump. Help me sleep at night.
Old Feb 5, 2008 | 02:23 AM
james562's Avatar
LMFAO
I was thinking it was a combination of too much fuel and not enough bottle pressure...
