Help picking DP...
Old Feb 10, 2008 | 10:36 PM
BADBOYZ28's Avatar
Default Help picking DP...
Well I sold my TNT F2 kit and am going to step up to direct port. I was going to go with a TNT F4 kit but the smallest you can spray is a 300 which is a bit much for me right now. I'm wanting to spray a 250 shot single stage. What kit would you guys recommend?? I just need some help/advice to deciede which one to go with....
Old Feb 10, 2008 | 10:46 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
This one
http://www.nitrousoutlet.com/installs/install.asp?id=56
The kit can be jetted as low as 100hp...but 200 and above is the most common
Old Feb 11, 2008 | 12:23 AM
firefighting1101's Avatar
the only way i would go is with a custom nitrous outlet kit...customer service is second to none and kits are top quality!
Old Feb 11, 2008 | 03:25 PM
BADBOYZ28's Avatar
What brand? LIke I mentioned I'v always had TNT. I loved it hits hard as hell. The Nitrous outlet has there own brand correct?
Old Feb 11, 2008 | 03:40 PM
Mike@HSW's Avatar
Here are two examples of intakes we have done recently. We can put together a quote for a single stage setup if you would like.
Old Feb 11, 2008 | 03:49 PM
quickblade's Avatar
Originally Posted by Ray@Nitrous Outlet
This one
DAM hello soon to be.....
That is the exact set up I am looking for... well I am throwing the 2 stage nozzle together to get thru the year, but when my baby goes trailer, that is what I will be getting from you ray...
thanks for posting that so I could see that... DAM...
cant wait.
Old Feb 11, 2008 | 04:01 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Sorry I meant to put this link in the above post.
http://www.nitrousoutlet.com/catalog...roduct_id=2790
The picture I posted is the same kit after our install. We have many different options we can add.
1) Injection Rails
2) Soft Lines
3) Colored Hoses
4) Paint
5) Anodizing
6) Polishing
7) Laser Etching
Pretty much anything you could think of we could probably do.
Old Feb 11, 2008 | 04:14 PM
Nitro Dave's Nitrous Outlet's Avatar
To add to rays Directport. Here are a bunch we have plumbed.
http://www.nitrousoutlet.com/installs/index.asp
We have years and years of plumbing experience!
Dave
Old Feb 11, 2008 | 06:49 PM
BAKED's Avatar
By God HSW is coming out with some really impressive stuff here lately. Those look awesome!
Old Feb 11, 2008 | 07:20 PM
Robert56's Avatar
You didn't mention if wet or dry was your goal. I would consider dry, as the tech has come by leaps and bounds. Dry DP is the bomb these days. All the benefits of the dry hit, and now direct port easily had for all. My choice for sure. Did you see the single plane intake thread, as there are a few DP Dry pics there. Anyway, which ever one you go with, wet or dry, Dave or Matt can set you up with some of the trick-est lay outs on the planet, bar none. We do have the best in the business right here on old ls1tech. Man it is a great time to be into the spray.
Robert
Old Feb 11, 2008 | 08:19 PM
99FRC's Avatar
Robert
AMEN TO THAT!!
99 FRC
Old Feb 12, 2008 | 03:54 PM
BADBOYZ28's Avatar
Robert
I want a wetkit. I used to have adry kit along time ago NOS 5177 and it was ok. IMO I like the wet better.
Are any of these setups without having to plumb the intake?
