HSW plate kit pics???
the dry plate is the same as their wet plate. If you look at it it says F and N on either sides. on the dry plate you have two lines running to the plate and looks just like the wet kit.
well their directions say to use both sides, I am assuming they have you do this for a reason, but can't see why just one side wouldn't work other than a vacume leak if uncapped.
Here's mine. I really want to re-route the lines so they don't loop around. I guess that's just how the kits designed and supposed to be installed? Worked great though...lotttaaaaa nitrous getting pushed through those lines/plate
. It came with the LS1/6 manifold 'noid mounts. They fit great, no clearance issues.
![](http://i24.photobucket.com/albums/c42/chrisricotta/0617082157-1.jpg)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i24.photobucket.com/albums/c42/chrisricotta/0617082158-1.jpg)
