Is this a good compression ratio for nitrous?
Old Feb 18, 2008 | 07:58 PM
WFOSS's Avatar
Default Is this a good compression ratio for nitrous?
I am rebuilding my motor with some Diamond forged pistons, Eagle h-beam rods, and Total Seal Rings. I am going with these Diamond pistons:
Diamond Pistons LS1 Forged Flat Top Piston set w/ -2cc Valve Reliefs, 3.905" BORE / 3.622" Stroke / 6.125" Rods / 1.315" Comp Height / .927 x 2.500
I was told that this would take my compression ratio down a little bit from stock. In addition, I was going to buy a set of heads that I was told have been milled, and that the C.R. on a stock 346 with these heads was 11.2:1.
That being said, my question is what will my C.R. be now with the heads and pistons, and would this be a good C.R. to have for a 200 shot on pump gas. I will also be running a set of ARP head studs. Thanks in advance for your help.
Old Feb 18, 2008 | 08:27 PM
transam69230's Avatar
Call a sponser like speed inc or LME they have always helped me out.
Old Feb 18, 2008 | 08:37 PM
408zo6's Avatar
x 2 LME that built my 408 and its 11.57:1 and loves the 300 shot!
Old Feb 18, 2008 | 09:15 PM
Josh@KY-Turbo's Avatar
The iron block 347 I am gonna run is 12.2:1. Should love the bottle.
Old Feb 18, 2008 | 11:08 PM
Nitro Dave's Nitrous Outlet's Avatar
Compression does not play near as huge as a roll like on a boosted application.
You will be fine.
Dave
Old Feb 18, 2008 | 11:51 PM
99mongooSS's Avatar
but what will his compression be with a 64cc chamber? and what will it be with a 59cc chamber?
