msd window switch part #
Old Feb 26, 2008 | 06:14 PM
CruzinCobalt's Avatar
Default msd window switch part #
what is the part # to the MSD window switch i need to safely run nitrous?
Also what else does MSD make to safely run my nitrous?
Thanks
Old Feb 26, 2008 | 07:03 PM
getusumws6's Avatar
do a search and you will def. find your awnser. they also make timing retarders
Old Feb 26, 2008 | 08:31 PM
BOLO's Avatar
I have the MSD Digital-6 Plus ignition pn#6520. It features two 100 rpm increments rev limits;start and single stage retards etc. etc.
I also have the MSD Digital rpm window switch pn#8969. Hope this help.
Old Feb 28, 2008 | 07:56 PM
adam`'s Avatar
does this mean the 8950 wont work?
Old Feb 29, 2008 | 10:23 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
There are many MSD window switches the 8969 is the digital unit...
http://www.nitrousoutlet.com/catalog...product_id=818
...this is a single channel window switch only.
These are our best sellers, bot come with a window switch, TPS activation, and a gear lockout feature.
Single stage
http://www.nitrousoutlet.com/catalog...roduct_id=2885
Dual stage
http://www.nitrousoutlet.com/catalog...product_id=964
As far as other items, what vehicle do you have?
Old Feb 29, 2008 | 11:33 AM
Summitracing's Avatar
LS1Tech Sponsor
CruzinCobalt,
The 8950 will not work on the LSx with out modification. I would look at the MSD-8940 TPS activated switch, or the MSD-8969 digital RPM window switch.
__________________
800-230-3030
www.SummitRacing.com
