msd twister or timing tuner?
Not at all just read the directions a couple of times. And note that the Crank Position Sensor is right behind the starter. Just like anything else take your time and do a good job with the wiring. Very simple to use.
I think I'm going to remove my console and mount the shifter directly to the floor and make an aluminum stand to mount the Timing Twister on and mount it directly to the floor on the trans tunnel somewhere.. Probably gonna put the wideband monitor on the same stand too. I think that would look pretty good myself!
Without Hp Tuners The Unit Really Couldent Pull Timeing As There Is A Iat Retard Multpulier Table In My Tune That Way Reduceing The "3 Deg" Max Timeing Pull Down To 1.5
After Resetting Some Tables In Hp Tuners Im Hopeing This Thing Can Pull Whatever Ammount Of Timeing I Want Now
