Car went bad lean on dry shot???
Old Mar 8, 2008 | 11:44 AM
KBOBOZ71's Avatar
i only had the 100 pill in on you, and it was prob lean as hell then too. thats why i couldnt feel it.
Old Mar 8, 2008 | 09:24 PM
FoolZRacing's Avatar
just like you picked up 80hp without a dyno
Old Mar 8, 2008 | 10:00 PM
1BADAIR's Avatar
if he added that much fuel in the tune then its gonna be a dog NA
Old Mar 9, 2008 | 01:40 PM
Robert56's Avatar
Originally Posted by KBOBOZ71
he just said that the mass must not have been able to keep up with that big of a shot. it was a 175 flywheel shot. he hadnt had a chance to tune on it before then, so it wasnt anything that he would have known before then
Tuner is wrong, we have gone to 300rwhp shot at about 4/6 inches from MAF. Many tuners really do not understand how a dry works.
Originally Posted by Sigforty
You are probably too far from the maf to properly read. The nozzle needs to be around 4 to 6 inches from the MAF for a good reading.
Yeppers, and pointed directly at said MAF, then some slight nozzle tuning can be done to fine tune a/f (rotating nozzle, changing style of nozzle, adding extra by pass nozzle, etc.).
Originally Posted by bjamick
Also dont point it directly at the MAF bc the nitrous will freeze the lil wires inside of the MAF and cause the car to run lean or rich.
Totally false, an old wives tale. If that were true, nobody could drive their cars in Chicago during the winter when temps get below zero on the freeway. Now the MAF screen can freeze due to condensation from the n2o, but we need to remove it for dry hits.
Originally Posted by brad8266
If youre running stock injectors they cant keep up with a 150 dry shot on top of a cammed car. You would be starving it for fuel.
If he was able to compansate with the n/a tune, then running out of injectors hasn't happened yet, but a good point none the less.
I didn't want to multi quote everyone, so will sum it up. Most gave excellent advice. For the most part, yes a nozzle close will give a better reading and thus be able to add the fuel needed. The problem with it being so far away, along with what Beer said on diluted reading, is air dynamics start to play a role (Dyno tune was correct on being close and missing MAF wires, but this happens, due to air dynamics, very, very seldom up close). Meaning, your n2o can be swept totally past, or around the MAF wires and give no additional cold reading. Nozzle tuning can work great, however, the key to good dry a/f tuning now is to use the HSW "Interface". This product is the absolute bomb for dialing in the a/f ratio on dry hits as well as wet hits, and has the benefit of timing pull, a great investment IMO. Also, this allows for optimum n/a tune. The reason you didn't hurt anything when hitting a 17.x:1 a/f ratio is the simple fact that is was a small hit and subsequent cylinder pressures were not that high. Though, a prolonged run could have hurt your motor. Good thing you didn't start out with a 250rwhp shot, and the reason we always say start small and work your way up checking all parameters as you go.
Robert
Old Mar 9, 2008 | 01:56 PM
Beer99C5's Avatar
On a dry hit your going above what you see on the MAF NA.
If he had a good nozzle location, he could tune only above the NA MAF Frequencies, it really won't have any effect on the NA tune (other than the timing if pulled).
Likely based on the nozzle position, I would agree that he added fuel and unless its setup on COS 5 or other software/hardware tricks, the NA tune probably suffers a bit.
Old Mar 9, 2008 | 02:39 PM
BrianC98Z28's Avatar
Robert
The man has spoken. Excellent advise robert as always. I have read and taken advise from robert on dry hits and setups back when i had one on mine and also when tweaking on buddys cars.
Old Mar 9, 2008 | 04:00 PM
KBOBOZ71's Avatar
all advice is appreciated. Robert, does it hurt to leave the nozzle where i have it? because we have a relay setup to kick on when i arm the system and this is setup in the tune to pull the timing and add the fuel that i need while spraying, this way my NA tune doesnt suffer. so now that its tuned, i dont have to rely on the maf anymore. so my real question is what is best for performance, closer to the maf or farther?
Old Mar 9, 2008 | 10:21 PM
04OUTLAW's Avatar
Damn boy you better get that "BIG SHOT" dailed in.
Old Mar 10, 2008 | 01:05 AM
He'll damn sure need too. No money for a clutch yet the car can be painted??? HMMMMM! Sounds to me like its always handy to keep a BS excuse in the pocket when ol blue is ahead.
Old Mar 10, 2008 | 06:46 PM
Robert56's Avatar
It's hard for me to say things are absolutely fine. If you see that your a/f is fine when spraying, then yes you can leave things alone. However, I suspect that the tuner just added to your WOT Power Enrichment multiplier and this will cause the n/a tune to run rich at WOT. Not really a big deal, other than missing a few n/a ponies from over rich. But then again, he may have done something totally different, so if ya trust him, you'll be fine. The relay could be connected to a resistor that fools another look up table that the boost guys use, IAT vs Fuel Multiplier. This way you can add an additional multiplier on top of the standard N/A multiplier and only comes into effect when spraying. I have messed with this way myself.
Robert
Old Mar 10, 2008 | 10:05 PM
KBOBOZ71's Avatar
Robert
thats exactly what he's doing. he's using the iat's. but as far as nozzle placement goes, where is best?
Old Mar 10, 2008 | 10:06 PM
  #32
KBOBOZ71's Avatar
DIALED.
Old Mar 10, 2008 | 10:07 PM
  #33
KBOBOZ71's Avatar
thats what the insurance company is for
and stay off my thread if you arent adding useful info.
