2 questions. timing and bottle pressure
The HPA or nitrogen is stored in the NANO bottle at 4500psi and stays a gas. It then has a pressure regulated pressure reduction valve that opens at 1000psi. As soon as it drops below 1000psi, it allows the gaseous HPA or nitrogen into the top of your N2O bottle, keeping it at a steady 1000psi. Keeping your N2O as a liquid at the bottom of your bottle to get pushed through the siphon tube.
You can only get so much consistency with the heater on a temperature switch, and only a little more on a pressure switch, then a ridiculous amount more with a NANO.
Now on the push systems. I have gone dual 15lb'ers to combat the pressure drop per run, and usually only drop 50psi or less depending on size of hit. My way is really based upon volume, and also has the benefit of not having to change a bottle out all weekend long. On the transducer (press SW), I have tried them all and they aren't close enough in keeping pressure where I like it. So, I chose to run with no auto control. Once we are done with a run I can flip my SW and the pressure is back up before I get back to staging lanes, then clicked off. Running a dry hit, we also use this method for changing hit size and maintaining a correct a/f, just up the pressure and bingo a bigger hit. That won't work very well with a wet hit though, as no way to change/correct a/f ratio. Now don't get me wrong, the push system is a great idea, but until some more companies offer this product (that will cause price to come down), I'll stick with what I have as the $$ can be used elsewhere. By the way, the 40hp gain that was claimed in the mag article, well a $5 jet can also add that supposedly missing 40hp, though the push system is more efficient at getting the most hp out of a given hit size. Something to think about for allof us, lets say we run brand Q kit and we get 150rwhp out of their 150rwhp jettin, now e add a push system and get an additional 40hp, whoa, a 150 now becomes a 190 hit? Wonder if the n2o companies have thought this one out?
Robert
Robert
with 2 stages or a 250 shot , I would put 116 in the tank also . just a little insurance.imo
last , Timing sorry i'm not a tuner. but a 250 shot you should be pulling some.Plugs i uuse8's and gap to 25
