NX on stock engine how much,,,?
Old Jul 24, 2003 | 02:34 AM
silverTA's Avatar
Default NX on stock engine how much,,,?
am thinking to spray 100 to 150 shot wet kit
on a stock ta A4 with ( hookersLTs,ORY,flow, NGKtr6 gap36)
so iis it ok to spary the 150
Old Jul 24, 2003 | 03:24 AM
fastls1inaz's Avatar
Default Re: NX on stock engine how much,,,?
hell ya...I spray 175 on my car most of the time,but toolin around 125-150.I have a a4 and on 125 my car went 11.50@118 bone stock on 255/50/16 bfg dr's....on 150 it's went 11.20@125.4
want some advise to hook...remove the front sway bar and get some et streets..my car cuts 1.52-1.60's all day with no converter spraying out of the hole....oh and your car is way more modded than mine so it should run real good.
Old Jul 24, 2003 | 11:50 AM
TWS's Avatar
TWS
So far I am only spraying a 75 shot on mine. However, it's an LT1, not LS1. I am playing it safe. Would rather lose a race than lose the motor. I am sure I could put a little bigger shot on it (100 or 125), but am just experimenting with it for now.
There is a guy I know here in town that routinely sprays a 100 shot on his basically stock LS1 and he has no problems.
Old Jul 24, 2003 | 04:38 PM
CAT3's Avatar
Restricted User
SilverTA, depends on yr of car. I wouldnt push too much, a 100wet sure. But with your mods, you might start starving for fuel on the top..especially if ya got a 99-00. Little injectors and stock pump on a modded car, may not be too cool at 150!
I would play it safe and stick w/ a 100, unless you get the 125 jet, but still....you can only push so much.
Old Jul 24, 2003 | 05:04 PM
DONAIMIAN's Avatar
I think its more of a question of how your fuel system and trany hold up rather than the motor
Old Jul 26, 2003 | 09:50 AM
Nitro Dave's Nitrous Outlet's Avatar
Put a fuel pump in it.Then spray the 150.00. Until then do not go over the 100 shot.Better safe than sorry.
Dave
Old Jul 26, 2003 | 07:50 PM
Chad00ws6's Avatar
Why not just put in the fuel pressure safety switch to make sure you don't starve it too much. A buddy of mine did it on his stock motor with a 150 shot and stock fuel system with no problems at all.
Old Jul 27, 2003 | 02:02 PM
silverTA's Avatar
what kind of fuel pump i need,size (H/C will be in after 3 weeks)
Old Jul 27, 2003 | 04:46 PM
According to NX you can spray 150 shot safely on a stock car.I just always recomend the fuel pump. However there are people spraying the 150 show with stock fuel pump.
Old Jul 31, 2003 | 01:59 AM
silverTA's Avatar
i did it today with 150shot what am ganna say wowowowowowow,,
thanx guys for the help
next week H/C will be in , a pigger fuel pump,tunning
Old Aug 4, 2003 | 10:02 PM
toxic99's Avatar
hell ya...I spray 175 on my car most of the time,but toolin around 125-150.I have a a4 and on 125 my car went <a href="mailto:11.50@118">11.50@118</a> bone stock on 255/50/16 bfg dr's....on 150 it's went <a href="mailto:11.20@125.4">11.50@118">11.50@118</a> bone stock on 255/50/16 bfg dr's....on 150 it's went <a href="mailto:11.20@125.4</a>
You must be spraying before 3000 rpm, WAY before 3k. Without a stall, you won't see 3k until roughly 60'mark. I know, cause my car is a stock A4 and I spray a 125 NX shot with a window switch set at 3k-6k. I am thinking you are full of **** or you just don't know what is in your car. And to answer the question, you will be fine up to 150 shot wet. If you do H/C or go bigger on shot, upgrade fuel sys. Or you could do it now for a peace of mind. Personally, I throw a couple of gallons of 101 unleaded in when I spray 150shot. Just my .02
Old Jun 2, 2004 | 01:03 PM
stangeater01's Avatar
i had a 150 on my car with no fuel modification had a stall exhaust headers intake on my 2001 ta a friend of mine had the intank warbro pump and ran a 200 on his ss
