melted plugs, still safe to spray again?
Old Apr 4, 2008 | 08:54 AM
dubrado's Avatar
Default melted plugs, still safe to spray again?
I melted 3 plugs, checked compression and it came out ok.
I pulled some timing and put in new plugs...safe to go?
or should I not spray it again?
Old Apr 4, 2008 | 09:08 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
What plugs were you using and are you using again? Tell us more about your setup as well please.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Apr 4, 2008 | 09:17 AM
Randy WS6's Avatar
What system are you running ? if wet , you maybe running lean and the drop your heat range on your plugs,And what gap on your plugs ?
Old Apr 4, 2008 | 09:46 AM
Chris@NitroDaves
Guest
Posts: n/a
Couldn't have said it better.......
-Chris
Old Apr 4, 2008 | 10:30 AM
dubrado's Avatar
tr6 gapped to .35
wet kit
125 shot
put in too much timing, wasn't showing any knock but stuff happens
27.5* at redline
Old Apr 4, 2008 | 10:35 AM
dubrado's Avatar
I already know what went wrong, my setup is good, jsut too much timing killed me
Had no issues w/26* but went up more and it didn't end up to well.
Now I have 22* in the car for now until I know it's safe to spray again and I'll prolly bump it to 24 or 26*
Just don't know if I should spray again
Old Apr 4, 2008 | 11:36 AM
SY732's Avatar
Whats your AFR?
I would richen it up what jets are you running what FP?
I did not know timming could melt plugs???
Old Apr 4, 2008 | 12:26 PM
01'WS6's Avatar
Originally Posted by SY732
Whats your AFR?
Detonation is a plug killer from jacked up timing.
Old Apr 4, 2008 | 01:16 PM
dubrado's Avatar
anyone detonate badly and then spray afterwards?
Old Apr 4, 2008 | 09:45 PM
dubrado's Avatar
bump, no one else lucky enough to melt plugs and spray again afterwards?
Old Apr 5, 2008 | 02:47 PM
built408's Avatar
I melted plugs before and didn't hesitate to spray again, but I have diamond forged pistons...
Old Apr 7, 2008 | 12:49 PM
SY732's Avatar
Whats your AFR?
Did you put colder plugs in?
What plugs?
Old Apr 7, 2008 | 01:22 PM
Unstang's Avatar
A friend of mine used kill TR6s in a stock short block with a dry kit, change them out & spray it some more.
If you've corrected the problem, I don't see why you wouldn't give it another shot.
Old Apr 7, 2008 | 01:36 PM
koolrayz's Avatar
some torco would help.
