Timing ?
Old Apr 10, 2008 | 10:56 PM
rocksws6's Avatar
Default Timing ?
So I hooked my car up to a scanner today and I'm pulling 26* of timing up to about 4500 then it goes up to 26.5* till 6k then it goes to 27*. I was trying to find out what the stock timing was but that didn't work out. Does anybody know what it is? What kinda timing is ideal for a 100 to a 150 shot? Should I not even try or should I be ok?
I will be running TR6 plugs and 93 octane. My mods are a lid, P&P TB, full exhaust, 230/232 cam. This is for NOS plate setup. Can somebody help me please.
Old Apr 11, 2008 | 07:14 AM
b4c346's Avatar
i'm running 22 degrees with the 150 shot.i would say 27 is too much.
Old Apr 11, 2008 | 09:31 AM
Chris@NitroDaves
Guest
Posts: n/a
From my understanding I believe the stock timing was between 24 - 26* from the factory. There are plenty of cars spraying 100-150hp shots without problems. If you wanted to be on the safer side you could pull about 2-3 degree's.
-Chris
Old Apr 11, 2008 | 11:55 AM
jmill96Z's Avatar
I usually hit 150 shot with 24 degrees, the drop it to 22 with the 200 shot
Old Apr 13, 2008 | 09:51 AM
rocksws6's Avatar
That's what I was hoping it was about 24* but no such luck. I appreciate the info guys. It looks like I need to back about 3* out of it so I don't have worry about detonating. Thanks again guys.
Old Apr 13, 2008 | 10:33 AM
jetblast's Avatar
don't mean to hijack the tread, but since timing is the subject, why is it that i'm running 15* with the 150 wet shot and rich mind you, and still can pull off 124mph and 11.29 et with 3750rwt.? so many guys are running 4 to to 7 more than me on the 150.
Old Apr 13, 2008 | 01:12 PM
BayAreaSS's Avatar
I would pull about 2 degrees to spray a 100 shot. I see your setup is coming along rock!
Old Apr 13, 2008 | 11:18 PM
rocksws6's Avatar
Oh yeah! All I got left to do is mount the bottle and wire everything up. Well I guess I gotta back timing off too. I would have it done but I just bought a house and my damn woman is wearin my *** out with **** to do. I should be spraying next weekend though and if I'm backing timing off it'll be a 150 I was going to try a 100 on the current timing but if I'm going to back it off its going to be the 150. I figured out why I couldn't get my car to hook up last strip trip. Too much air pressure. I figured 25 would be good but it seems everybody runs about 18 so if I can get it hooked up and spray it I should hit 11's which is the magic # I'm after right now.
You made it to the strip yet?
Old Apr 14, 2008 | 01:41 AM
BayAreaSS's Avatar
No i haven't made there yet. I've just been cruisng around enjoying the car. I'll go to the track soon i hope
