HSW new n2o interface users
McBride
are you adding fuel on top end?
Robert
McBride
ALSO I FOUND THE JETTING #'S ON THE INTERFACE TO BE KINDA REALTIVE... JUST CHOOSE WHAT EVER MAKES THE WIDEBAND HAPPY AND YOUR GONNA BE GOOD...
ALSO IF YOUR TUNE HAS BEEN MODFIED THE #'S TEND TO BE MORE OFF
IN THE END (AT LEST FOR ME) THE HSW INTERFACE WAS NOT A GOOD IDEA.. I ENDED UP PULLING IT AND GOING BACK TO A N20 TUNE (FOR TIMEING) AND JUST LETTING THE N20 PLOOM FROM MY HALO TELL THE MAF TO ADD FUEL
I dont see why this would be any different for a 2000 vs any other as my understanding is that it uses the IAT tables to pull timing. I dont have one. Just curious.
McBride
FURTHERMORE THERE IS A MODIFER TABLE FOR THIS TABLE BASED OFF OF RPMS.. WHEN LOOKING AT MY STOCK TABLE IT WAS SET SO EVEN THIS 3 DEG PULL WAS NEGATED TO ONLY 50% WHEN YOU WERE IN HIGHER RPMS
THEREFORE EVEN IF YOU SET THE TUNIT TO 158 DEG IT WOULD ONLY PULL 3 DEG OF TIMEING AT LOWER RPMS
TO USE THE UNIT TO PULL MORE TIMEING YOU MUST MODIFY THE TABLE TO PULL MORE TIMEING AND CHANGE THE MODIFER TABLE SO IT DOSENT FADE OUT THIS CHANGE...
"I'm offended! no spray yet, all NA.
I'll get back to you guys on the cam specs" quoted from mike at hsw.
Robert
I think the BEST thing would be for HSW and algws6 to agree to make the best attempt to resolve this in some way. They could do it in the old thread...or by PMs and emails and phone in private.
Makes no difference to me...just a thought.
