About to spray. Few questions
Old Apr 21, 2008 | 01:09 PM
JBourne's Avatar
Default About to spray. Few questions
Ok, I have the dry kit set-up and am about to spray. I do have a few final questions, mainly for safety.
Plugs - I am only going with a 100 shot 52 jet, Can I use my NGK TR55's, or would the recommended plug be the TR6? If I can stay with my 55's, what gap would you run? Right now I think mine are at about .058"
Timing- I forget what it is at now, I will check when I get the lap-top on it, but how much should I take out? I'm thinking 2*, but all the information on it says 2* per 50 h.p., so that would be 4*. What are your thoughts.
Old Apr 21, 2008 | 01:22 PM
streetassasin's Avatar
I'm running TR-6s gapped at .035" you should be good with timing on such a small shot. I dont plan on pulling any timing until I step up to a 150 shot
Old Apr 21, 2008 | 02:01 PM
nova2427's Avatar
I would pull timing for anything greater than a 75 shotl.
Old Apr 21, 2008 | 02:47 PM
JBourne's Avatar
If I run the TR6's, can i gap them to .040" and run my car on motor as well. Will the TR6's being gapped that small cause a decrease in performance on motor?
Old Apr 21, 2008 | 05:23 PM
1969mach1's Avatar
Im running a 125 wet (cold fusion) with stock OEM Delco plugs, stock timming with a Hypertech tunner performance tune... Car runs great, no problems here...
