Guys with 408s and spray please come in...
Old May 2, 2008 | 09:07 AM
  #41
1ORANGEWS6's Avatar
Originally Posted by TheBlurLS1
I ran 28* N/A. I went down to 16* just for tuning/safety sake on juice, and have since ramped it up to 20* now that I'm comfortable with the AFR it's running on gas. I am about to install some type of aftermarket timing control device because pulling a bunch of timing turns my car into a turd N/A.
On 16* of timing and 3900lb raceweight, I went a measily 123mph. On a 100 shot I picked up 9mph, only spraying 2-4th, and my car goes over 50mph in 1st lol. I started a thread about timing loss + N/A runs and have come to the conclusion that I was loosing over 50rwhp dropping 12* of timing.
I believe if your tune is good and leaning on the rich side, you could run a 200 shot on pump gas easily. My AFR is 11.2-11.0:1 depending on bottle pressure. Just make sure you use colder plugs than TR6's. If you're realling leaning toward pump gas, and want a little extra insurance, have them throw in a bit bigger cam and run the compression no more than 11:1. I have a relatively small cam (242/246), quite a bit of compression (11.5:1), and get away with it.
Rick at Synergy is going to spec my cam so I'm sure it won't be as big as yours. My compression will be the same as yours though at 11.5:1 with a 72 cc CB and 1 cc dome piston. So I may be okay but I'm probably going to use the WCCH L92s which can have a bigger 75 cc chamber so I could lower my compression if needed.
I have a timing tuner and you can flip a switch to pull timing for your nitrous but I can't remember how much be cause I haven't used in a while. I'm like you though I want the best of both NA and NO2. Right now since I don't have my timing tuner set up I'm running a NO2 tune so NA is a little off.
Old May 2, 2008 | 04:29 PM
  #42
TheBlurLS1's Avatar
That's what she said...
I want a timing tuner that will only pull timing when the spray is ON, not when the spray is armed. When I have my 1st gear lockout on, and not spraying 1st, I want it to run 28*. When the gas comes on in 2nd, I want it to knock down the timing.
Old May 2, 2008 | 06:14 PM
  #43
Robert56's Avatar
Originally Posted by 1ORANGEWS6
don't know if mine will be gapped the same or not since mine will be setup for the L92/L76 setup but I will get some head studs just incase I ever want to go above a 200 shot.
Man I have really got so good info out of this thread!
Yes, always build for bigger than you plan, lol. We all need to live by this rule as no one ever stays at the level they originally wanted. Those ARP L19s are the ticket, IMO, and offer 40% more clamping force compared to the standard ARP studs, though they do cost a few $$, but good insurance for the buck.
Originally Posted by BayAreaSS
I have been reading this thread and i agree this is a very helpful thread. I have been toying with the idea of getting a 408 with a 150-200 shot
Thanks for the good info guys.
The added 75lbs is the turn off for most guys. For me saving the many $$$ over other options was a no brainer, a 5 dollar jet will compensate fine for the added weight. The best bang for the buck motor out there, bar none. You will not be sorry. hell, the 3800 $$ short block and my stock heads and baby cam n/a 430/450, me is happy.
Me too, I think I posted in that thread, anyway we lost just about 50hp going from 27° to 14° and a couple other slight changes. But that was just to test my loss, as my normal tune in HPT for the dry doesn't effect my n/a tune. You know the Interface will work fine for the wet hit also, it can make fine tuning the a/f a breeze, and/or will allow changing of the a/f per daily weather changes. Then it also has a timing pull, and in the intro thread we talk about the advanced features of the timing pull. For about $150, or somewhere close, it's really a steal, and can be used in the future on any type of kit.
Another thing now that I remember is that Brian at LME asked how much was I plan on spraying. I told him probably a 200 shot. He said that would be fine to stay there so I wouldn't have to worry about head gaskets. My head gaskets are going to be .051 thick. I didn't ask him but wouldn't he gap the rings according to the amount of spray I planned on using? Did you plan on a 300 shot from the start? Since you have GM head gaskets it doesn't appear that you have any trouble spraying bigger shot but I guess the head studs help out a good bit with that.
Yes, from the get go Brian knew that 300rwhp shot was my goal, and they built everything to my exact specs, though they did choose the ring gaps for me. The GM MLS gaskets seem to work just fine for the bigger hits. I have run only these on all my LSx builds/cars. Some say they have had issues with copper gaskets, but I haven't used them on these motors so can not verify good or bad. I wouldn't be afraid to have them gapped for a slightly bigger hit, just so your covered later. It really won't hurt anything at the small change needed to go say from 200 hit to a 250hit, but it's your call. The LME 408 is good to about 1000hp, anyone know of someone getting close to that number?
The one thing to watch on the L92 heads is the exhaust side of things, stockish heads don't flow real well compared to to other aftermarket heads on exhaust side of things. There are better n2o heads out there. Now if they are working your heads over with spray in mind then you will be fine. If no special work on the exhaust side, then get a cam with plenty of duration and lift on that side compared to intake side (consult your cam pros). Remember, we will have much more to exhaust on the spray and no more increase on the intake side, compared to n/a. You still flow the same volume as n/a, say 100% n/a, and on the spray 80% air and 20% spray (still 100% as some volume has been displaced by the spray), same volume, until we get in the combustion chamber. Then we have more introduced fuel, and the n20 oxygen has been released at 5xx° (IIRC), then this additional mix ignites and becomes more to exhaust, than n/a. Hope that made some sense, lol?
Robert
Old May 7, 2008 | 02:46 AM
  #44
BayAreaSS's Avatar
Robert, I'm not afraid of the extra weight. That means i just need to make a little extra power to make up for that weight. I have a question for you guys with 408's.
Is $8k enough to build a 408 and get the fuel system taken care of?
Old May 7, 2008 | 07:10 AM
  #45
1ORANGEWS6's Avatar
What kind of mods do you have now?
Old May 7, 2008 | 08:31 AM
  #46
Nitro Dave's Nitrous Outlet's Avatar
I personaly prefer the advantages of having a dedicated fuel system in the car. With the dedicated I run C-16 and 93 in the stock gas tank. You will only unes small amounts of fuel from the dedicated so it will last longer than the nitrous bottle will. By using the C-16 it will help aid in detonation as well as illiminate the possibility of getting methonal cut fuel from the gas pump that may swell the fuel plunger on the fuel solenoid.
We use to build alot of dedicated using JR dragster fuel sells and inline fuel pumps and regulaters. That is why WE designed the all in one dedicated. Our all in one dedicated have a walboro fuel pump located in the cell. It comes with a aeromotive regulater that you can adjust for high or low fuel pressure. The system comes with all the hoses, fittings, wiring relay and diagram. The tank is fully assembled and you simply just bolt it in. The quality of our dedicated is yet to be matched.
Take a minute and check them out. We keep them in stock and on the shelf most of the time....
http://www.nitrousoutlet.com/catalog...del=73&dept=11
Another option would be to upgrade your current fuel system to dual intake pumps. Let me know if I can be of any help to you. Just shoot me a pm..
Dave
Old May 8, 2008 | 12:42 AM
  #47
BayAreaSS's Avatar
Right now i have full bolt ons and a cam. I also have a wet nitrous kit with nitro dave's plate.
Old May 8, 2008 | 01:15 AM
  #48
randomnine7's Avatar
i had a question might be a dumb one but ..
with a dedicated fuel system .. will the fuel sell suply fuel to the rails and all injectors? or just the the fuel solonid ?
im wondering if this would be the best way for my rx7 project ..also u would have to upgrade stock injectors right ? even if u run c16 gas during the nitrous use ?
Old May 8, 2008 | 07:57 AM
  #49
1ORANGEWS6's Avatar
The dedicated fuel system can sends fuel to the fuel solonoid of your wet nitrous kit or to the fuel rail for a dry kit.
If you are spraying a dry kit it would be a good I dea to change your injectors depending on how big of a shot you planned on spraying. If you are running a wet kit you won't have to change your injectors because the extra fuel is delivered by the fuel solonoid. It would also depend on what type of mods you have. When I did my H/C swap my stock injectors were at 105% duty cycle.
Old May 8, 2008 | 08:58 PM
  #50
its a full bolton forged 347 with ms4 fast 90 and prc heads ///
im sure i would max out the injectors on motor power and im trying to run a 3 stage 300 shot .. 150 plate kit and 2 smaller 75 dry shots ..
im not sure on wich to go with dedicated kit or upgrade full fuel system .. not just the injectors as im trying to do .
Old May 11, 2008 | 01:28 PM
  #51
Robert56's Avatar
Check out the thread on how to extend the injector capacity running a dry hit, very simple really and could save the purchase price of a new set of injectors.
Robert
Old May 11, 2008 | 01:40 PM
  #52
Robert56's Avatar
Originally Posted by aNuBiS
I am in the same boat, I have upgraded pump and wire kit, big injectors and high HP big cubes build, I dont like the idea of pulling directly from my stock rail anymore.. looking for alternatives.
I didn't see this before, but the stock rails can support 700hp. The real problem is the supply end of things and the regulator at the tank. The pulling from the rails for a wet hit would be ok if we would put the regualtor at the rails and of course the return.
Robert
