What AFR to shoot for on 100 shot Stock Bottom End
Old Apr 30, 2008 | 09:03 AM
stevegrizzle's Avatar
Default What AFR to shoot for on 100 shot Stock Bottom End
Just wondering what you guys think I should shoot for.
I have the LC-1 Wideband, 100 dryshot I usually try to keep the bottle @ around 900-1000 psi to keep the initial hit from being too hard.
Right now I am right around 12.5.
Is this too far on the edge? I am basically using the PE mode to richen it up over 3k which is where I spray.
Please guys tell me your thoughts
Old Apr 30, 2008 | 11:07 AM
Come on this is an easy one. Little help?
Old Apr 30, 2008 | 12:18 PM
caliswangin916's Avatar
11-12 a/f. i try for 11.5. you can go leaner but the hp isn't worth it for me if it's even there.
Old Apr 30, 2008 | 12:26 PM
I am getting no knock at 12.5 but it worries me since most say what you say?
Has anyone spray 100 @12.5 for any substantial period?
Old Apr 30, 2008 | 01:27 PM
021less's Avatar
in my opinion that is too lean, mine on the 100 shot wet, 950psi is 11.5-11.8. Its 12.8 on motor.
Old Apr 30, 2008 | 01:42 PM
2THOUSANDZ's Avatar
Thats really lean. As stated before, I'd shoot for a target range of 11.5-11.8 AFR
Old Apr 30, 2008 | 01:44 PM
jmill96Z's Avatar
I shoot for 12.7 on motor, and 11.5 on spray. I'll drop down to 11.2 on a 200 shot though.
Old May 1, 2008 | 12:05 AM
Jamie 97 C5's Avatar
Im at 12 on a 100 dry shot.......some say its not rich enough but its fine for a 100 shot.....
Old May 1, 2008 | 01:06 AM
jmill96Z's Avatar
Just get good practice on reading plugs.
Old May 1, 2008 | 10:15 AM
Re tuned it for 11.8 on spray, still pulls almost the same and added piece of mind
Thanks for all the replies guys.
Old May 1, 2008 | 10:24 AM
Chris@NitroDaves
Guest
Posts: n/a
11.8AFR is right where you want to be....Time to let it eat
-Chris
Old May 1, 2008 | 03:07 PM
are you suggesting a 175?
Im still on stock clutch so it might be an exercise in futility.
Old May 2, 2008 | 07:19 PM
Robert56's Avatar
Yea, a stock motor and a 100 shot the cylinder pressures are not very bad. So, you'll likely cause no harm. Some would consider this the edge, but IMO, hardly. Hell some of the record times I was setting in the Z06 stock LS6 with a small dry shot were this lean and leaner. So, it really depends on your comfort level and I like tuning to the "edge", but also understand the ramifications if something goes wrong. This is where it gets personal choice, running this lean you have removed a nice safety net compared to a 11.5:1 ratio, so if you have an issue elsewhere would your motor survive? Probably would, but can you afford this if things go wrong and you need repairs? I always new i could eventually blow my motor, but that was my goal from the beginning to see how far a stock motor could be pushed, and i will tell you these LSx motors can handle a lot of abuse (old threads can give insight on my stock motor). Now with all that said, if you can, get it into at least the high 11's.
Robert
