nitrous line routing from spare tire area
Old May 5, 2008 | 12:02 AM
pHEnomIC's Avatar
Default nitrous line routing from spare tire area
Should the nitrous line be run inside or outside the car and exactly how should I route it from the spare tire area?
Old May 5, 2008 | 01:09 AM
SPEEDYTRANSAM1996's Avatar
Old May 5, 2008 | 01:24 AM
MeanWS6's Avatar
I just cut a hole in the trunk (vert), ran the lines under the car (following the fuel lines) and back up to the engine. 8yrs no probs
Old May 5, 2008 | 01:33 AM
BayAreaSS's Avatar
I ran mine inside the car. I ran it along the door sill and under the dash through the hole behind the pcm
Old May 5, 2008 | 01:48 AM
jmill96Z's Avatar
I run 'em inside along the door sill
Old May 5, 2008 | 05:37 AM
socmguy's Avatar
Restricted User
I wanted to run mine outside but it was a little easier to run it inside for my center console gauge.
Old May 6, 2008 | 01:12 AM
Old May 6, 2008 | 05:11 AM
95 Z28's Avatar
I ran mine through the door sill too, then through that hole behind the PCM. I couldn't get the damn plastic sill cover to sit/snap in right though.
Old May 6, 2008 | 09:13 AM
Chris@NitroDaves
Guest
Posts: n/a
When i used to have mine in the truck area i ran it inside the car along the passenger side under the side molding on the door seal up through the gromet on the firewall beind the PCM. I had to cut the gromet in order to fit the nitrous line through but once i did that everything was good to go.
-Chris
