Best setup
Currently I have an ls1 with:
full bolt-ons
intake manifold
5.3 64cc heads
G5X3 112LSA cam
42# ford green injectors
The car makes 438rwhp and 385rwtq
My questions are as follows:
1.) What is the best type of setup and brand for this? (I'm thinking 150 shot)
2.) What parts do I need?
3.) With a 150 shot, what type of power should I see?
Get a bottle heater, a purge, and a window switch.
Colder plugs also. Run good gas and you are good to go. What kind of fuel pump do you have? You should see around 150hp, every car is different.
I would say a base kit, window switch, heater, purge, and plugs is a good start, as well as possibly a better fuel system (pump, Boosta pump...).
You are set up for a dry shot with your 42's, I would favor a dry kit with the HSW interface (unless you have access to HPT or EFI Live) for tuning.
The which is safer wet or dry is a couple days reading, do a search for everyones opinion in that exclusive LS1tech thread LOL.
Call the vendors to learn about the various system types and get their opinions (they after all have the most expierence with the systems they sell); Dynotune (Dean/Dan), Nitrous Outlet (Chris/Ray/Dave) and Harris Speedworks (Matt), have always answered my questions without pushing a sale.
Dynotune wet kit $380
Purge kit $60
Bottle heater $120?
Window switch (MSD digital?) $80?
TR6 plugs $20
Fuel pressure safety switch $?
Walboro fuel pump w/ wiring <$200
Gauges & pillar pod $?
Not sure I want to go that route yet though.
The dry kit uses the factory fuel system to add enrichment fuel. Thus needing larger injectors above a certain point.
dp
dry
plate
wet nozzle
direct port has the best distribution of fuel and nitrous per cylinder and when you go to a bigger shot i believe the intake design leaves the #7 cylinder out of wack. again ive never tested this first hand but only read about it. id say since the high end plate systems are 800 bucks and a direct port kit is 1200 spend the extra bones and get something you wont have to replace on down the road. do it once, do it right.
I dont want to spend a crazy amount of money but I am willing to spend to do it right.
