n20 v6?
Old May 26, 2008 | 10:40 AM
jetlag's Avatar
Originally Posted by scott94z
YEAH!!
I do have a brand new set of MT 27x10.5x15 et streets off the 94 turbo car(went to the 315/60/15 mt's)
low 12's would be worth it!!
If a 200 shot will give you 200rwhp..and I know it will give a ton of torque.... how much do they dyno at stock? 160? So... 360hp, 400tq...yeah, low 12s
Old May 26, 2008 | 04:01 PM
scott94z's Avatar
today I replaced a coil pack(was corroded) and all the plug wires(2 corroded, 1 was open), when I bought it, it was only running on 3 cylinders, .....took the car out and beat the snot out of it...runs like a top now
I have an extra 3.42/limmited slip rearend with disc brakes off of a z28 camaro...Going to install this and some weld wheels with some et streets, then I need to buy anouther NX kit
Old May 26, 2008 | 08:38 PM
krazy4's Avatar
Should be pretty interesting!
Pill it till you kill it.
Old May 26, 2008 | 09:29 PM
scott94z's Avatar
lol
Old May 26, 2008 | 09:40 PM
RaggedRides's Avatar
Better watch it there. Sprayed V6's might make you forget those LT1's you been screwin' with
Don't shred her without a decent video!!!!
Old May 27, 2008 | 06:57 AM
scott94z's Avatar
I won't let you down.....I will vid when it happens
Old May 27, 2008 | 03:45 PM
Linxs's Avatar
People tend to be shocked at what our "little" v6's can do with the right attention. I'm interested to see what it does!
Old May 27, 2008 | 09:56 PM
scott94z's Avatar
What do you guys think....nx wet kit? plug change and race fuel??
Whats to record for a stock 3.4l with spray??
Old May 28, 2008 | 08:33 PM
scott94z's Avatar
whats the v6 stock motor w/ n20 record??
Old May 28, 2008 | 10:15 PM
97rs4life's Avatar
12s have been done with the 3.8l engine.
Old May 28, 2008 | 11:28 PM
scott94z's Avatar
impressive, will the 3.4 live to run 12's???
Old May 29, 2008 | 12:15 AM
  #32
giiventofly's Avatar
kind of doubt it... thats like a 4 second gain from spraying. realistically a very stock 3.4 on spray would be lucky to see high 13s low 14s imo
Old May 29, 2008 | 01:57 AM
  #33
Misflt's Avatar
I think you would get quite a few runs out of a 100 shot. I dont know about the iron pistons holding much past that.
Old May 29, 2008 | 06:11 AM
  #34
scott94z's Avatar
true
Old May 29, 2008 | 04:14 PM
  #35
Alt's Avatar
Alt
This thread is too old to not have results yet.
Old May 29, 2008 | 05:52 PM
  #36
FATHERFORD's Avatar
I had a buddy that sprayed a 200 pill through an old 2.3 ford motor trying to blow it up. All it did was melt the plugs.
Old May 29, 2008 | 06:15 PM
  #37
scott94z's Avatar
just want to get all the info possible, don't want to just jump into things. I tend to get better results then.
besides this is only a side project ...the turbo car is the primary focus
but it will happen this summer
Old May 29, 2008 | 06:42 PM
  #38
Bird_Of_Prey's Avatar
There was a guy from MFBA that went low 14's in a 3.4 on a 75 dry shot. He sprayed it pretty regularly. Those 3.4's have TINY injectors from what I can remember. Around 19lb/hr and the fuel pump isn't very strong either. If you have an extra fuel pump laying around, go that route. 150hp won't last long, I bet the trans goes first though.
Old May 29, 2008 | 06:47 PM
  #39
dutinsss's Avatar
this sounds like it's going to be fun haha. but i bet when your trying to blow it up it's not going to. so in that case, get some 500 shot jets and have a good'ol time!
Old May 29, 2008 | 07:03 PM
  #40
Linxs's Avatar
do a wet kit, and run race fuel if you care about the engine. I think the 3.4 record is in the 13's. I would not expect much better than that. Assuming the tranny holds up.
