Nitrous Daves LT1 plate, any 200 shots?
Called Nitrous Outlet and spoke with them about how much their plate will flow. They said I could safely go up to a 400hp shot at the motor. This was assuming I was using a standalone fuel system running low pressure(10psi) and a NANO system. He gave me the jetting for 150hp-300hp for now. Since I'm still on a stock bottom end I figure I'll start at 150hp and work my way up. The limiting factor is going to be how fast the car runs. I don't have a cage yet. I'm also going to use the Trick progressive controller/gauge to ramp it in.
This is Ray from Nitrous Outlet
The plate will physically flow up to 400 HP...but as Dave said above, once you start going 200+, you need to play close attention to the distribution. We have many LT1 guys running 200 or more through our plate.
Here is one
install....
http://edholio.smugmug.com/gallery/4...91016762_6oELj
Dyno results...
http://www.nitroustech.com/forums/showthread.php?t=333
Here is one
install....
Dyno results...
Here is one
install....
Dyno results...
Here is one
install....
Dyno results...
I run 300 on a lt1 with an old O Mallys spray bar kit . I tried a few different plates and nozels. I say 200 on a plate is the point in where you start having problems. 150 with nozels .
Adding all this LS engine stuff is just confusing the entire post.
Later,
Brad
