Timing Tuner install question
When I turn the key ON they both blink and then go off.
When I start the vehicle the green light comes on and stays on.
Is that right?
then I tried to program the upper RPM:
I adjusted the switches on the tuner.
I started the vehicle and the red light came on for about a second or so and then went off while the green light stayed lighted.
So does all this seem right to you?
https://ls1tech.com/forums/showthrea...=501965&page=6
thats the way i did it and it works perfect.
I have two relays. One came with the kit and one with the bottle heater. Does it matter which I connect into?
I get the alternating green/red lights.
The gray wire should be hooked to the 85 pin.That should be the only wire hooked to pin 85.
The box will provide ground once it get to your set rpm.
White wire goes to your arm wire. It just needs to see 12 volts when your system is armed so it knows when to ground the 85 pin.
Most people tie into the arm wire after the wot swtich.
My problem is I hook up the 85 pin and the other wire like said above. Then, I arm the kit with the key on, press the pedal WOT and there is no clicking of the solenoids.
Is that right?
