N2O motor build, callies compstar or Eagle rods?
Old 06-09-2008, 12:12 PM
Frost's Avatar
Default N2O motor build, callies compstar or Eagle rods?
TSIA
A buddy is building a stock-inch forged LS1 that will see as much as a 300-shot, and other than the ARP 2000 rod bolts, has asked me which is a better rod, the Callies Compstar or Eagle H-beam.
I don't know which would be a lil beefier, so I thought I'd ask you guys. Thanks for your time.
Old 06-09-2008, 12:23 PM
Frans96SS's Avatar
Callies are Deff beefier.... i would think eagles would be good up to a 300 but i would prefer the callies.
Old 06-09-2008, 12:40 PM
Frost's Avatar
I told him that, but his builder (big time sponsor here) says they are good for the same duty, so I wanted another opinion.
I have the Callies and ARP 2K bolts in my turbo motor...
Thanks for your input.
Old 06-09-2008, 02:41 PM
LS2Camaro's Avatar
I was also told Callies are better, they are in my turbo motor.
Old 06-09-2008, 04:28 PM
bad6as's Avatar
what about pistons?
Old 06-09-2008, 06:42 PM
BAKED's Avatar
From what I understand "Compstar" is basically Callies "budget" rods.
When I was building my motor tey were about the same in my book as far as strength goes. The Compstar rods come with the arp 2K standard bolts and the Eagle's don't. I ended up getting a better deal on the Eagle's so I got them. I've hit them with 300+ multiple times with no problems.
Old 06-09-2008, 06:50 PM
firefighting1101's Avatar
im going with compstar crank and rods...with weisco pistons, and gfx rings. the motor will be seeing a 300+ and i was told that it would have no problem doing so.
Old 06-09-2008, 08:01 PM
ssfast99's Avatar
my new build is compstar/callie all the way.
Old 06-09-2008, 08:26 PM
MOSTDELUXE's Avatar
They are bolth a 4340 forged H beam rod........What makes a callies beefier? They look exactly the same to me.
Old 06-09-2008, 08:51 PM
ATVracr's Avatar
Callies in mine and Shiz's motors with no problems.
Old 06-09-2008, 09:03 PM
Randy WS6's Avatar
I have Eagle rods with a 300 shot and L19 ARP rod bolts, And never had any problems at all.
Old 06-09-2008, 11:02 PM
Frost's Avatar
Not that I don't take every one else's word here, but this is nice to hear.
I had a few setup questions that I was gonna hit you guys with through PM at EFA, if I don't touch on anything too top secret
Thanks everyone.
Old 06-10-2008, 07:23 AM
ATVracr's Avatar
Thanks everyone.
Here or EFA is fine, There isnt much top secret stuff in them.
Just learning what to do with the parts once you get them is the problem.
I'll help you out with what ever I can.
Old 06-10-2008, 10:09 AM
Race your car!
JL ws-6's Avatar
All the mentioned rods are good. I have a set of billet eagle rods in mine, and they're doing just fine so far.
L19 bolts/studs everywhere as well, for whatever that is worth
Old 06-10-2008, 11:02 AM
SmaknaSS's Avatar
I never hear about the eagles going out. I just went with the eagles and ARP 2000's as well. We'll see how it goes.
Old 06-10-2008, 11:23 AM
Race your car!
JL ws-6's Avatar
Exactly. You never hear about cranks or rods going, both have been around for long enough that they're solid. Blocks and pistons, on the other hand are a differnet story LOL
Old 06-10-2008, 12:26 PM
yeh the eagle and callies are made of the exact same 4340 aluminum...the difference is the callies are just a little easier to intall. there machining is just a little more precise. if your building the motor yourself definately go callies, and if your having it built then go eagle because you wont be the one worrying about the install anyways. neither one should have any problem with upwards of 1000hp. your pistons will fail before the rest of your stuff.
Old 06-10-2008, 01:14 PM
Race your car!
JL ws-6's Avatar
Pistons, head gaskets, rod bolts all come to mind as being culprit's of problems before the crank/rods.
Then at about 1200 hp I think the main caps start walking, so again you have other issues before the crank or rods are a problem.
Old 06-10-2008, 05:13 PM
TwistedSS's Avatar
Venolia all the way. LOL $$$
