NitroDaves / Trick WS wiring question....
Old Jun 22, 2008 | 11:21 AM
02blackbeauty19's Avatar
Default NitroDaves / Trick WS wiring question....
I am wondering why the white wire from the window switch AND the blue wire have to be tied into the WOT switch. Can anyone give me some advise?
I had my system wired up to a MSD WS where I only needed the red wire from the WS to tie into the WOT switch and ARM switch so now im wondering why I cant do the same with this window switch?
Old Jun 22, 2008 | 11:26 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
White is power and blue is tps input. They are not suppose to be at the WOT switch. Can you post a pic of the drawing you are looking at./
http://www.trickperformanceproducts....nstruction.pdf
Old Jun 22, 2008 | 11:43 AM
If I splice the white from the WS into the wire from the WOT to the ARM....Where does the blue one go
Old Jun 22, 2008 | 11:55 AM
myfast70's Avatar
The blue wire will tie into the N.O. side of the WOT switch (the wire that actually goes to pin 86 on the relay). That way the only time the blue wire will be activated is under WOT. If you were to put it to the COM side of the WOT switch then it would be constantly armed and just waiting to see the correct RPM.
Old Jun 22, 2008 | 12:08 PM
Ok so Ill tie the blue one into the relay side of the switch and the white one into the arm side of the switch....correct?
Old Jun 22, 2008 | 12:40 PM
1LastTime 69's Avatar
blue wire goes to the BLUE tps wire on the side of ur tb....
Old Jun 22, 2008 | 02:04 PM
myfast70's Avatar
yes that is correct
or you can use this method also.
I just thought you did not want to use the TPS switch on the TB so I did not mention that method. Some people prefer the WOT switch over the TPS signal.
Old Jun 22, 2008 | 02:42 PM
Ok cool thanks guys. Im all done im just waiting on a buddy to tune it and then it will be test time
Old Jun 22, 2008 | 08:31 PM
let us knw...
Old Jun 22, 2008 | 09:40 PM
NXRICKY's Avatar
Blue wire goes to either the TPS or to the WOT OUTLET terminal (relay terminal). The blue wire lets the window switch know when you are at wide open throttle.
If going to a wot switch, you have to program the box as such.
Old Jun 23, 2008 | 12:22 PM
u do not need a manual wot switch... its all in the ws
Old Jun 23, 2008 | 05:03 PM
I thought you could use it either way? Since I already had a good setup, I figured I would just leave it like so
