Track Time Estimate
Old Jun 25, 2008 | 12:42 AM
kdavis's Avatar
Default Track Time Estimate
I would like a time estimate for my car. I have a 99 trans am with an slp lid, pacesetter 1 3/4 longtubes, egr/air deleted, tr6 plugs, msd wires, 3 inch custom y with 3 inch to the axel and a cutout, as well as all the free mods, except the p&p tb. circle d 3600 stall converter, and a transmission cooler, and lakewood control arms. I will be racing with 274/40/r17 micky tompson et street radials. My rear end is a detriot locker with moser axels geared a 3.42. I am planning on spraying a 75-125 dry shot off the line. What do you guys think i will hit?
Old Jun 25, 2008 | 12:57 AM
jmill96Z's Avatar
My guess would be 12.0 on a 100 shot.
Old Jun 25, 2008 | 01:04 AM
kdavis's Avatar
well i hit a 12.4 on a 75 shot off the line before the headers, stall, and ory
Old Jun 25, 2008 | 01:07 AM
BayAreaSS's Avatar
I think you can pull off an 11.8 on a 100 shot out of the hole
Old Jun 25, 2008 | 08:26 AM
1969mach1's Avatar
12.0 With the 75 shot, headers, ory, and stall.
Old Jun 25, 2008 | 11:47 AM
stereotypicalv8guy's Avatar
I hit a 7.7 (12.0) with headers, 75shot, subframe connectors, MT Streets, and a tune. So my guess would be low to mid 11s for you with that stall...if you can get it to hook. I had huge problems with bogging on the stock stall.
Old Jun 25, 2008 | 12:30 PM
kdavis's Avatar
hm. that sounds nice. i am either going to use hoosier drag radials or mt drag radials either at 12 psi. the mts are 275/40/17 and the hoosiers are 255/50/16
Old Jun 28, 2008 | 12:31 AM
dnkynrbk's Avatar
you will not hit mid 11 with out heads and cam. Weight of the car? I would say high 11s maybe 12 flat. watch your air fuel if you run a bigger shot. Do not go over a 100 shot if you have a stock fuel system and injectors. A buddy of mine did and KBOOM.... NO MORE #7 PISTON OR THE EXTRA RODS THAT WENT THRU THE BLOCK LOL ON YOUR D.R. TRY THEM AROUND 15 TO 18 Is where they hook better. They are not a slick. I had the same set my car and found out 17 lbs was best. GOOD LUCK
Old Jun 28, 2008 | 11:30 AM
robsquikz28's Avatar
what he ^ said as well. these drag radial companies actually recommend tire psi to be set between 15-22 but thats what the track is for
Old Jun 29, 2008 | 08:45 AM
Z-RATED94's Avatar
My guess would be high 11s also. I run my MT street (drag) radials at 22lbs. hot. The next time out I'm thinking of trying a couple of lbs more to see what happens. So far it dead hooks every time, but then again it's not exactly a high HP car.
Old Jun 29, 2008 | 09:04 AM
Oh really? Funny, cause I'm on stock fuel system spraying a 150shot and have been through 10 bottles on the 150shot. If your tuner knows what he's doing you can do it.
Old Jun 30, 2008 | 09:52 AM
Z-RATED94's Avatar
Funny? Stock pumps are known to be a crap shoot. I'd rather not trust the factory piece when spraying. Why try pushing the stock one to see how far it will take you? To say you've done it?
Old Jun 30, 2008 | 10:19 AM
jmill96Z's Avatar
10 bottles huh? That makes you a seasoned veteran. Care to elaborate how your awesome tuner increases the reliability of a stock fuel pump?
Old Jun 30, 2008 | 02:49 PM
ScreaminRedZ's Avatar
registered user
I'll guess a high 11. Keep us posted.
As for the fuel system, alot of people run them without a problem, but alot run them and run into problems. Personally, I'll be upgrading mine.
Old Jun 30, 2008 | 05:37 PM
I never said anything about increasing the reliability of the pump. Someone said that you can't spray that much on stock fuel system, I take that as meaning there isn't enough fuel to do it and that's just not true. Yes, my fuel system is maxed out but you can do it.
As for the seasoned veteran crack, I never made that claim but thanks for the praise
Old Jul 3, 2008 | 11:31 AM
kdavis's Avatar
i race next week and i am still on a factory tune. i am trying to get a street tune from a buddy of mine because i dont have enough time to go do a dyno tune. the shift points are way off due to the higher stall
Old Jul 11, 2008 | 02:28 AM
kdavis's Avatar
I hit an 11.9 with a 1.6 60. I didn't spray until the .60 and let out of the spray before 3rd. It hit the limiter 6 times
Old Jul 12, 2008 | 05:59 AM
508Stroker's Avatar
Get that tuned and drop a few tenths!
Old Jul 12, 2008 | 07:23 AM
rocksws6's Avatar
You have to jet it to run rich so that it doesnt' lean out so much on the top. That's a shitty way of doing something if ask me. I would rather not half *** it myself. After all a fuel pump kit is a whopping $250. Why even try it?
Old Jul 14, 2008 | 10:14 PM
kdavis's Avatar
What fuel pump is that? Granitelli is 120.
