dry kit
Be careful about nozzle placement. I tried 2 different locations but my car was still going too lean. So I bought the Interface from Harris Speed Works. It will let you put the nozzle anywhere, and you can dial in your Air Fuel ratio.
Nitrous Outlet sells a bottle mount that fits in the spare tire area, if you didn't want to fabricate your own.
Like I said about nozzle placement..it's hit or miss on some cars. I put my nozzle in a spot that a lot of people said worked fine...it didn't..went lean so I tried another spot...went lean. Now my SLP lid has 2 holes in it..haha. With the HSW Interface, you don't need to worry about where it is placed.
I bought a PLX wideband setup for $225 from a sponsor here. So I can monitor my air fuel ratio with it, and adjust it with the Interface.
Do not try spraying unless you are on a dyno or have a wideband!! I didn't have one, and went terribly lean and could have destroyed my engine.
