wtf-cos5 wiring?
Old 07-04-2008 | 06:16 PM
ls2 bait's Avatar
Default wtf-cos5 wiring?
just popped the covers on the pcm and there is no wire in the pcm? so how the heck are you guys grounding this thing? also which pin 56 is it-the red or blue harness?
Old 07-04-2008 | 06:30 PM
Randy WS6's Avatar
Its the RED conector,You will need to get a pin from a old harness or order a new one. Were do you live ? I have a few with a bout 6" of wire on it from a old harness ,you can just sorder a longer wire to it. That is what i done and it work perfect.
Old 07-04-2008 | 06:35 PM
Randy WS6's Avatar
Go here and this will help you
http://forum.efilive.com/search.php?searchid=235859
Old 07-04-2008 | 06:40 PM
Beer99C5's Avatar
Pins are like 50 cents from eficonnection dot com or something similiar...sure a google would find it.
Remove the connector, punch a hole in the yellow rubber,
Insert pin and you will feel it snap into place. Reinstall connector.
Old 07-04-2008 | 06:45 PM
myfast70's Avatar
Sorry to take this thread off topic a bit but can this also be done with HP tuners?
Old 07-04-2008 | 09:52 PM
ls2 bait's Avatar
ahh im pretty sure i have one of those laying around. ill have to look tommorrow. thanx guys
Old 07-05-2008 | 02:14 AM
JoeyGC5's Avatar
Come on I wanna know how well the wiring is gonna work
Old 07-05-2008 | 07:10 AM
Beer99C5's Avatar
Joey, the wiring works great, LOL the tuner is what needs help
The COS 5 I have pulling the timing perfectly when active, the VE Multiplier I have not seen work. I am using a rocker for turning it off and on.
The Purple Grey and Black wires on my pic I inserted to the EGR PCM Pins, it is my 5V power source for my sending unit (Fuel Pressure) and ground as well. The Purple wire is tha voltage for the Fuel Pressure PID through the EGR. The lone Black wire is the COS5 (goes to a rocker for ground).
Old 07-05-2008 | 01:53 PM
Loudmouth LS1's Avatar
I just setup COS 5 on my car last week, just have to wire it up when I get the spray back on it, gonna have it go off a relay that's tripped from my nitrous arming switch so I don't have to worry about flipping any other switches!
Old 07-05-2008 | 07:11 PM
ls2 bait's Avatar
what joey helped me with was using the second stage wire from my window switch to activate my cos 5 as im only running a single stage
Old 07-05-2008 | 10:18 PM
dlove's Avatar
i just pulled a pin and wire out of like the cruise control wire or something. Then moved it to 56. I use mine for the 2 step.
which btw joeyg, i got mine wired up thanks to you!
